Thread: kudos to TFP and BBB
    Thank you, thank you, thank you.
    We have had our pool for fifteen years, but were ready to give up. We used chlorine for the first 8 or 10 years and although there were some reasonably good years, the pool was never 'crystal' clear. We switched to Baquacil, and like most people it worked good for the first few years then went steadily downhill.
    We had to replace the liner two years ago, but once we refilled the pool we were NEVER able to get it clean enough to see the bottom. We invested a small baqua-fortune but nothing was able to clean up the mess. Near the end of last season I was searching the web for help when I stumbled across TFP. We decided to give it a try this year, but made up our minds that this would be the last year. If it didn't work we'd pull out the pool and put in a flower garden instead.
    We bought the test kit before opening the pool this year, and have followed BBB religiously. Wow, what a difference. Our pool is clearer than I can remember it ever being. Thank you for giving us our pool back.
    24' AG, 12,000 gal, vinyl liner, no heater or solar
    Jacuzzi Laser 190 sand filter with 50 lb pea gravel and 150 lb sand
    Feb 2008
    Denton, TX
    5,061
    Re: kudos to TFP and BBB
    Welcome to TFP!
    Glad to hear that you made the switch and are enjoying your little oasis again. Now you can plant flowers around the pool instead of turning the pool into a flower garden!
    30,419
    Kat,
    That's great testimony. Discovering the simplicithy of BBB has been a revelation to virtually all of us at one point or another.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi katamoron,
    Wonderful story. So glad you have your pool back!
    Welcome to the forum
    You're done SLAMing when:
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    "Knowledge is power"
    Glad that your pool won't become a garden
    Luv& Luk
    -Ted
