Thread: Liner attachment methods
    Jun 2016
    Melbourne
    1
    Hi from Australia!
    I am looking at doing a DIY besser / cinter block construction pool. Been reviewing as much info from TFP as i can, as well as speaking to as many people with experience as possible. Tho i would like to clarify are the attachment methods of the vinyl to the pool wall.
    Ive seen one pool liner that had a v-shaped rubber around the complete edge, and it clicks into a track that is fixed to the side of the blocks.
    Another method is folding the edge of the liner (which is just plain) several times, and then "pushing" into a track. Is this the most common method?
    Or are there other methods?
    Cheers!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Liner attachment methods
    Welcome to TFP
    Here is a list of the liners, I have an intex so my choice was easy
    Above Ground Pool Liner Types: Overlap, Unibead, Beaded Expandable
