Thread: Calculating Gallons
    Jul 2015
    Sarasota, FL
    43
    Calculating Gallons
    Pool is 16'wide by 32'long rectangle. 5.5' deep in the middle sloping to 4.0' at the ends. Think volleyball pool configuration as slope up from middle is even on both ends. What gallonage do you calculate?
    Thanks
    Randy
    15000 gal in-ground rectangular concrete/pebble-tech pool. Hot Springs Prodigy 325 gal spa.
    triptyx's Avatar
    Apr 2016
    1,438
    Re: Calculating Gallons
    Go to Pool Math (the link is above in the blue nav bar), scroll to the bottom, select Rectangular, enter your length and width, and estimate your average depth, and voila, gallonage!
    After that, if you have a recommended test kit, you can carefully test your FC, pour a carefully measured dose of bleach into the pool, then within about 15 minutes test FC again. Put your old FC as "current", your new FC as "target", then play with Gallons until the amount of bleach you poured in comes up and presto - you have an extremely close estimate of your volume.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    38,305
    Quote Originally Posted by triptyx View Post
    I would not call this a one and done. The strength of bleach can vary. Over time if you consistently are missing your targets for all chemicals, then you could adjust the volume.
    triptyx's Avatar
    Apr 2016
    1,438
    That's an excellent point Jason, thanks for the clarification!
    Jul 2015
    Sarasota, FL
    43
    The question is volume. I'd always been thinking 15000 gallons but if you average middle and end depth you get 11000. A big difference.
