Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: frustrated. SLAM taking foreva! and mustard algae?
    Jun 2015
    jenks, ok
    41
    so, i'm on day 10 of a slam, and the water is clear (imho), i'm getting lots of sparkle, but i still can't pass the overnight test. i'm brushing/vacuuming twice a day (every square inch, i promise!), cleaning the cartridge filter every other day, and checking the fc levels at least 4 times a day. i'm tired. i'm almost out of the powder, and have more being sent, but i'm not sure if it will get here before i run out.....
    There's also something on the floor/walls, that just isn't going away. not sure if it's metal or algae. we've had issues with metal in the past (thanks pool store guy!) back when my husband was in charge of the pool. when i scrub on it nothing happens.
    anyhoo- i'm stumped. there are probably 20 empty jugs of bleach in my trash can, and the trash guys will probably think i've cleaned up a crime scene.
    i just really don't know what to do. i'm so frustrated and disheartened. and my husband is thinking this process isn't working, and we should go back to the old way of doing things. any thoughts? i'm desperate, please encourage me.
    17ft round, 6800 gallons, AG, vinyl, cartridge, city water
    Oct 2015
    Katy/Texas
    411
    Re: frustrated. SLAM taking foreva! and mustard algae?
    What are your test results?
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Jun 2015
    jenks, ok
    41
    i was under the impression that i wasn't to test anything but the chlorine and the cya while in slam. the cya is at 30, so, i'm trying to maintain a 12 on the chlorine.
    these are the #'s before i started the slam.
    FC-7
    CC-5
    TC- 12
    PH- 7.2
    CH- 300
    TA- 180
    CYA- 0
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    you got it right just chlorine tests during slam.
    your cya was 0 when starting then did you up it to 30? (looks like from what you said, just asking)
    how much chlorine do you lose over night?
    Dolphin E10 Cleaning Robot.
    Jun 2015
    jenks, ok
    41
    yes, i added cya in a sock to get it up to 30, then started the slam
    i bump it up to 12 usually around 10pm, and by morning, it's back down to 3 or 4
    Nov 2015
    Chicagoland, IL
    205
    That's a rough run of work. :/ do you have any pool lights, or any places that algae could be hiding? In ladder holes, in/under steps?
    27,000 gal. plaster IG with round spa built in 2007. TFT-100 test kit XL w/ Speedstir
    Jandy CL580 cartridge filter. Jandy 1.0 hp filter pump, 1.5 hp booster/spa? pump.
    Aqualink RS One Touch controls. Paramount PC2000 In-floor cleaning system (1.0 hp pump?). Jandy LX pool heater, apparently broken.
    Missing so much gear due to previous foreclosure, it's sad.
    Jul 2014
    Hudson, wi
    81
    IMO (and this is just what I have done) I use the numbers on the chart as a minimum. If you aren't going to be swimming in it while you slam keep it above 12 for CYA of 30. If you are going to be using the pol during the slam use the 12 as a max while in use. If you hit it hard it knocks out the algae faster. Sounds like you are not keeping the Fc up enough to take care of the algae. Also I go by my pressure gage to tell me when to clean out my filter, when pressure increases 3psi or so I do a quick backflush (sand filter). I just went through a lot more gallons of 12.5% slamming mine. stay with it.
    21,000 gallon IG with vinyl liner, Pentair sand filter, TF100 test kit, pool is about 15 years old.
    new in 2016 - Hayward SWCG with T15 cell
    Jun 2015
    jenks, ok
    41
    no lights. just added the pool ladder 3 days ago, and i was tired of hauling my 50 year old self out of the pool without it. i'm being extra aware of the skimmer, tho.
    Jun 2012
    Butler, PA
    336
    Can you take a picture of the whole pool ~ so we can see what you see looking in? A view picture from a bit of a distance that shows the pool and the water, but not right down in the water.
    When did you add the CYA?
    The "stuff" on the walls does it have any texture to it, is it slimy, if your eyes are closed can you tell just by feel you have touch a spot of the "stuff"
    Your chlorine I know you said you had a ton of jugs in the trash ~ might have possibly made the crime scene alert list. Is your liquid chlorine "fresh", stored out of the sun and heat?
    You are out of powder, what type of powder?
    You had trouble with metals in the past, how long ago? Was it this same water?
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    Oct 2015
    Katy/Texas
    411
    Make sure you maintaine the CL at slam levels. If it drops in a few hours, boost it back up.
    Jun 2015
    jenks, ok
    41
    here she is from above, sorry about the shadows from the trees.
    to your questions: i added the cya the night of the 6th, and started slamming the morning of the 7th.
    I can feel no difference with the "stuff".
    most of the bleach was fresh-ish. i had a few jugs of bleach that i found out later were old. however, the past few days, i've been using bleach with a 2016162 date on them.
    the powder i'm almost out of is the DPD powder.
    yes and no and maybe it's the same water? lol.... last year when we had the issue, we emptied and refilled half the pool. this year, husband didn't tighten down a hose well enough, and the pool half drained itself. I'd say no, it's not the same water, but obviously, i have no idea what i'm talking about.
    Jun 2012
    Butler, PA
    336
    Ok ~ how about testing the CYA again since you added it the 6th ~ if you haven't already to verify that is is sitting at 30.
    It's a pool with a ladder you just introduced and that skimmer. Can you really work on the nooks and crannies of that skimmer box~ toothbrush it if possible.
    Also is there by chance wrinkles on the bottom that could be holding some nasties?
    Full Sun ~ All Day
    Jun 2015
    jenks, ok
    41
    i checked the cya on the 11th (wanted to make sure it got up to 30), but i'll check it again. i've got a hand brush for the skimmer, but there's a couple of spot that're really really hard to get at, right under the bladder, and right up against the wall. i'll use my grand daughters toothbrush, she'll never know. bwahaha. there are some wrinkles on the bottom. i try to make sure i scrub em good, but who knows, that's a possibility.
    so, i could still be having these issues from those spots? mercy me.... i may never get this thing cleared.... yikes!
    Jul 2014
    Hudson, wi
    81
    Yes, Where all my edges seal around my stairs I take the brush edge to get in the small cracks and there is a ton of stuff in there. If not taken care of it will just hang around until the Fc drops and then bloom like you wouldn't believe.....or maybe you can. keep at it. I do my deep cleaning by hand when I am in the pool, then raise the FC up again.
    Jun 2015
    jenks, ok
    41
    ok, then. i'll just keep at it. and i'll tell my husband that we're sticking with this method until further notice. i do the same, work with the burshed in the pool, get out, test and raise FC, wait a few hours, wash, rinse, repeat....
    Jun 2012
    Butler, PA
    336
    If you verified the 30 probably no reason to test again as you haven't done a water change.
    I would have to think the nasties have to be associated with the skimmer box.
    You'll definitely get it and once you do it will be smooth sailing and honestly so much more economical to maintain ~ it's just right now you have some seriously secretive funk in there that needs found and blasted out.
    Please keep us posted as you go
    I am pleading the 5th if Granddaughter questions about the toothbrush, lol!
    Full Sun ~ All Day
    Jun 2015
    jenks, ok
    41
    will do. thanks! is it safe to assume (!) that the crud on the bottom is just super tough algae, and will eventually leave my life?
    Jun 2012
    Butler, PA
    336
    if said crud is stains and it's organic, elevated FC levels could lift it.
    if said crud is metal staining I don't know how they lift the metal stains, I am sorry about that.
    now if said crud is matter moving on the bottom that's your whole issue.
    I can't really see the bottom I do notice the reflection of the trees but I can't see anything on the bottom.
    Full Sun ~ All Day
    Jun 2015
    jenks, ok
    41
    said crud does not move at all. wish it would. you can't see the crud in the pictures in the first post?
  20. Back To Top    #20
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    If it's a stock cartridge filter it will take longer to clear. Is that asoft-sided pool? It might be stained, but could clear up if you maintain your FC correctly.
    Did you test the CYA to verify what you added took it to 30?
