Thread: trying to add a hayward H250 heater to this setup
    Jun 2016
    MATAWAN,NJ
    1
    need advice on parts I will need and how to go about plumbing this,it's a pretty old setup I will be adding a H250 Hayward pool heater and eventually sungrabber panels,added a pic with the heater,I'm going to elbow directly out of the filter to the inlet of the heater and connect the outlet to the manifold already made,may move the heater around the corner to get it away from window,any suggestions would be appreciated
    Hi all and thank you for this forum and any help you can give me,ok trying to get stated older In ground 30'X15 oval 4' shallow 6' deep end.Hayward EC65A D.E,2 hp motor,vinyl liner
    Casey's Avatar
    SW PA
    10,453
    Re: trying to add a hayward H250 heater to this setup
    Welcome! Bumping to get you answers.
    Jun 2012
    western NY
    1,561
    I think the manual will have some instructions on how close you can be to windows, doors etc.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
