Results 1 to 7 of 7
Thread: Will I need new filter cartridges if I convert to SWG?
    May 2016
    Toronto/Ontario/Canada
    68
    Hi there! My filter cartridges need replacement which will set me back about $600. I am also thinking of possibly converting the pool to SWG at some point in the future. If I need new cartridges after converting to SWG then maybe I should hold off the purchase until I make up my mind about the conversion. Please let me know your thoughts. Thanks
    In Ground Chlorine Irregular Shape (21,000 gallons), Cartridge filter Sta-Rite S7M120, Pentair 342001 SuperFlo VS, Vinyl Liner , Gas Heater Raypak P-R265B-EN, Test Kit Taylor K-2006, Filled with Tap Water, NO Spa, Several large trees towering the pool, Pool and equipment several years old but look in reasonable shape
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Will I need new filter cartridges if I convert to SWG?
    The filter cartridges have nothing to do with a SWG.
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Agreed, saltwater or not makes no difference to any pool equipment. Take a look at Pleatco filters, I am very happy with mine.
    May 2016
    68
    Great to know. I believe my neighbor was sold a set of new filters when he converted to SWG which confused me. I might not have the full story there though. Thanks for the reply!
    May 2016
    68
    About the Pleatco filters, pooldv, can I do that? I thought I can only get the OEM "Sta-Rite 25021-0200S & 25022-0201S System 3 S7M120" and they are really expensive. I will definitely check them. Are there any other good brands in case Pleatco is not available in Canada?
    As you can probably tell by now, I am very new to pool ownership
    DFW, TX
    24,483
    I don't know if they are available in Canada. Pleatco has a great website and even better customer service. If you tell them what you have they will figure out if they can help you.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    There are several brands that you can use. Don't pay extra for OEM, there is little difference in performance.
    chiefwej
