Thread: Filtered or Not for Waterfall
    bluetahoe's Avatar
    Sep 2014
    La Vernia, Tx
    34
    Have one of those aluminum ornamental windmills mounted and anchored to concrete pool deck just for looks. Idea is to run some pvc over and up it then over the pool to create a "waterfall" effect over the water. Think I've got it all figured out-wont need seperate pump as the pool pump has nothing else on it but the pool, and the gpm of the waterfall will be minimal. Question is, is it better to run unfiltered water back to the pool for the waterfall or filtered or does it not really matter?
    Thanks
    16x32 rectangular, 19,000 gal, gunite, quartzscapes plaster, Hayward Tristar 2 speed 1.5hp pump, 31" Hayward Pro Series sand filter, TF-100 test kit, BBB method rocks
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,776
    Re: Filtered or Not for Waterfall
    It should be filtered water. If for no reason other than to keep your waterfall clean of debris.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Apr 2013
    Sacramento, CA
    2,769
    Generally you want to run an additional return over to the waterfall controlled by a jandy valve. You can set the jandy valve so it opens to the proper volume.
    bluetahoe's Avatar
    Sep 2014
    La Vernia, Tx
    34
    Perfect. Thanks guys.
