Results 1 to 8 of 8
Thread: Who knows about a Heater suction temperature reading?
    Marty D's Avatar
    Jun 2016
    Quogue new york
    146
    The pool heater is on. Set at 83. Pool temp is 83 and has been 83 all week. On the menu select is suction temp actual 52 f. What is this ? I called pentair pro technical and asked him. He said its actual water temp coming into heater. But how can that be if water temp says 83. He said the bottom of pool water is colder. I started thinking and the pool is sucking from top of pool. Out came the book but I can't find any info. Says call a pentair tec. What is this ?
    38,524
    Re: Who knows about suction temp?
    There is no way you would have a 30 degree difference from the top to bottom of the pool.
    I am guessing that something is wrong with the temperature gauge ...
    I am going to change your title and move this to a better forum that might get more attention.
    Marty D's Avatar
    Jun 2016
    Quogue new york
    146
    I got to download a pict of pool.
    The gauge say 83. The suction says 52. I just asked my buddy. AC guy. He says its for the built in AC. I don't know much about elect pool heaters. Why would it even have a AC built in? My buddy asked if its a elect heat pump or elect heater. I have no clue. That's why we have this site.
    38,524
    Re: Who knows about a Heater suction temperature reading?
    What heater do you have? (not that I can help, but trying to gather info for someone who can)
    Please add your pool details to your signature as described HERE as it will help us help you.
    Marty D's Avatar
    Jun 2016
    Quogue new york
    146
    Pentair 140 elect Heater. Ultra temp heat pump 140 BTU
    mas985's Avatar
    Pleasanton, CA
    11,742
    From the manual
    8. Suction Temperature Screen
    Shows the suction line temperature of the refrigerant. This screen appears if the Defrost is enabled.
    This is the temperature of the refrigerant at the input to the compressor. Has nothing to do with water temperature.
    Mark
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,832
    That's actually a handy number to know for curiosity and troubleshooting of the system.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Marty D's Avatar
    Jun 2016
    Quogue new york
    146
    Makes sense. As it works hard all day, that number drops. Started at 56 and now it's 49. Thank you. Marty D
