Thread: Pump and Filter mismatched?
    May 2014
    Newmanstown PA
    37
    Hey everyone. I have a 24' AGP and I'm in the process of converting from filter to sand. One of the members here recommended a 300lb Hayward sand filter (S244) along with a Hayward (SP1592) 1hp 2 speed pump if I chose to replace my Proline 1.5hp 2 speed pump. On eBay I found both Hayward products from "saveonpoolsupplies" and the total is about $500. I messaged them to see if they had a one auction combo with both of the products and they mentioned that the pump I was looking at is AG while the filter is IG and they are mismatched. Is this correct and if so is it a problem? If it is what other pump and filter should I be looking at?
    ***My pump and filter will be approx 15' away from my pool, so about 30' of piping to and from. I plan to plumb in 1.5" pvc piping below the frost line.
    -Judd
    38,237
    Re: Pump and Filter mismatched?
    A filter can not be AG or IG ... it is just a filter
    They probably think that AG filters are smaller, but when you have a lot of water, a bigger filter is needed.
    You will be fine.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Just because one is labeled AG and the other IG doesn't mean they're mismatched. 1 HP is plenty for your sized filter. You'll get better filtration if your pump isn't oversized for your filter anyway. The only part that might be awkward is the fittings to hook the pump exit to the multiport valve, depending on the style of the fittings and adapters on each.
    Isolated Spa - 345 Gallons
    May 2014
    Newmanstown PA
    37
    You will be fine.
    Haha this is why I joined this forum Thank you, I appreciate it.
    -Judd
    24' Round AGP / 15,000 Gal / Hayward Powerflow 1HP 2SPD / Hayward S244T Sand Filter / Pool Rover Jr. / TF100 / ...
    May 2014
    Newmanstown PA
    37
    Quote Originally Posted by JVTrain View Post
    Thanks for the response and input. I'm hoping I don't run into issues with the fittings. I figured if worse comes to worse I can get different size in/out adapters at Lowes or Home Depot. Sometimes I feel the pump/filter combo is overkill for my under 15000 gallon pool when i see your sigs with almost the same pump setups and similar filters with double or more pool.
    -Judd
    Feb 2014
    Central Minnesota
    5,080
    My filter is certainly undersized for my pool. I have a 500 lb filter and I wish I had a 700 pound or larger. I had to go with the 27" filter for my pool simply because of space reasons on my pad. Wish I could have put the 31" filter in. Your old pump was oversized for your pool and you'll save a little more $ on electricity with the new one. Bigger is always better for filters!
