Results 1 to 13 of 13
Thread: Proper CYA level
    Jun 2016
    East Central MS
    115
    Proper CYA level
    The climate in which I lived previously was not as hot and did not have the direct sunlight experienced here in central MS (i.e. further north). I used to maintain my CYA between 30-50 ppm, and this is what pool school recommends. In an environment with greater temperatures and more direct sunlight, should the CYA be maintained a little higher to help protect the chlorine? Say 60-80 ppm? Curious as to your thoughts. Thanks.
    34K gal, 20'x40' IGP (backfilled and reinforced concrete block walls with concrete floor built mid-1970's; renovated 2017), PebbleSheen Arctic White plaster finish, Lotus Prisma Marine 1x2 glass waterline tiles, Indiana limestone coping, 1.5hp Hayward pump, Pentair Triton II TR100 sand filter, Pentair Intellibrite 5g color LED 120v Pool Light, Dolphin Supreme M400 robot, Stenner 45M1 pump, Pentair 320 chlorinator (to raise CYA only)
    JoyfulNoise's Avatar
    May 2015
    13,170
    Re: Proper CYA level
    Try 60ppm first and see how that affects your FC each day. If you feel you are having to add to frequently (assuming your daily FC loss isn't too high and due to an algae problem) then increase to 70ppm.
    Matt
    May 2015
    Land O Lakes, FL
    527
    If you have a screen enclosure, it will have a effect too since it reduces the amount of sun rays received. A screen enclosure blocks about 30% of the sun.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Jun 2016
    East Central MS
    115
    How much is too frequently? Right now I am adding about a gallon of bleach per day to maintain 7 ppm FC with a CYA of 65. The pool does see full sun with a water temp in the high 80's/low 90's for sure.
    Jan 2012
    'burbs of Augusta, Georgia
    7,239
    Consider 2-3ppm daily loss expected. If your loss is more, raising the CYA is a prudent thing to do. How are you testing?
    Jun 2016
    East Central MS
    115
    Hmmm, I'm not too far off that. I'm losing somewhere around 3-4 ppm daily. I guess I could increase CYA a bit. Testing with a Taylor K-2005. FAS/DPD reagents are on their way.
    Jan 2012
    7,239
    ...and your water is sparkling clear...right? If you start testing with the FAS-DPD test and your FC drops more, and your CCs rise up it says something is in your water chewing up your FC. Always be on the look-out for that.
    Good job ordering the FAS-DPD tester!
    Jun 2016
    East Central MS
    115
    I'm actually losing somewhere between 6-8 ppm FC per day. It's clear to 4-5 feet, but has never fully cleared since opening this year. My CC is only 0.29. The previous owner had painted it and all of those paint chips are now flaking off. Perhaps could be contributing to cloudiness? I'm wondering if I should raise my CYA a little due to the sunlight, heat, and FC loss. Also, if in really hot and sunny environments the CYA should be above 50, why does Pool school not mention this?
    Jan 2012
    7,239
    I think you need to perform an OCLT (overnight chlorine loss test) to determine if the cloudiness is the chipping paint or something eating away at your chlorine. Algae will do that for sure. Overnight Chlorine Loss Test
    Can you vacuum to waste the bottom to get the paint chips out? After you've brushed the sides well of course.
    Jun 2016
    East Central MS
    115
    Will do. I will perform the OCLT tonight.
    Yes I can vacuum the paint chips to waste, but they keep coming. They are incessant. It will be a constant battle until I get my pool resurfaced next year...
    May 2015
    13,170
    Depending on the type of paint used, you may not be able to pass an OCLT but it is still worth doing. The chipping paint represents a constant debris load but it could also be adding to your chlorine demand as well. See what the OCLT tells you and we'll try to help you figure this out.
    Matt
    Jun 2016
    East Central MS
    115
    I got my answer (at least part of it). I came home from work yesterday afternoon and my FC was 1. There was obviously something in the water chewing up my chlorine. So I started a slam. The water already looks better this morning. That being said, I know it will be a constant battle with the chipping paint until the pool is resurfaced next year. I hate pool paint.
    Jun 2016
    East Central MS
    115
    The water is now clear and I can see the bottom of the deep end. Took my sand filter about five days to clean up. Using a lot less chlorine as well. Seems I did have some residual algae since opening that is hopefully now gone for the season. Thanks for the help.
