Thread: Question on bead receiver
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    578
    Quick question. Since this pool is new to me and we got it used, I am wondering if I should have taped the seams where the bead receivers meet up? I was in the pool earlier and noticed that if the water gets to moving it occasionally will flip up above the bead. I've looked in the instructions that I downloaded for this pool and I don't see any place in there where it says to.
    There was minor surface rust in a few spots on the inside of the wall when we set it up and we brushed those areas and sprayed with a rust inhibitor. So that got me realizing those areas were right where the receiver butts up to each other and water got in there and caused that to happen. Going back to my question, should it tape over those seams? Or seal them with something or just leave them be?
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Apr 2013
    Sacramento, CA
    2,769
    Re: Question on bead receiver
    The Seams don't require tape but its an area that may have problems. Even with tape they are an area prone to rust.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    578
    Thanks. I guess I'm just being over paranoid. I kind of figured that it wouldn't matter. I guess water is going to find its way where it wants to go regardless. I just want this pool to last. Everything on this pool is resin except for the top caps and wall so it should be good for a long time.
    Apr 2013
    Sacramento, CA
    2,769
    The top cap is metal bolted together around the top of the pool?
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    578
    The plate that sits top of the post that the top rails bolt to. That is what I was referring to that is metal.
