Results 1 to 10 of 10
Thread: Newbie builder of freeform pool question
    May 2016
    ada, mo
    32
    Hello all! This will be my first pool ever. I am getting a freeform 18x38 pool. I am measuring the pool as they just sprayed the outline of it. Should the smallest point to point be the 18 feet across or is that the largest point the 18 feet? I have measured the smallest point to point and its 16.5 feet across.
    Thanks for any help!
    May 2015
    Fullerton, CA
    634
    Re: Newbie builder of freeform pool question
    personal preference and shape will dictate that.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Jun 2016
    Central Valley, CA
    31
    Most of the plans for free form pools I have seen mark point in the deep end and have a radius from the point to four points on the edge that indicate the LxW. These edge points are not necessary in a straight line across from each other going through the fixed spot indicated in the deep end. From what I have seen, usually from the spot marked in the deep end show measured lines drawn out to the furthest point on the edge. So your 18x38 might actually measure smaller if using straight lines.
    May 2016
    ada, mo
    32
    So this is the original drawing and then the outline they came and sprayed. I feel like it does not look like the drawing. Would appreciate any thoughts/suggestions?
    Thanks
    Sep 2015
    Tucson, Arizona
    86
    Difficult to tell for certain, but the spray-painted lines marking the waterline look to me like they match up with the curves on the drawing. Do you have an engineered drawing with measurements that you can compare to your actual measurements? If you are concerned, talk with your pool-builder about it. Remember that the layout always looks smaller than it will look once the hole is dug.
    Owner Build. 32x16, with 6x8 raised spa. Broke ground April 1, 2016, swimming July 18. Pentair Intelliflo VS + Whisperflo for Water features; Clean & Clear Filter 420; Master Temp Heater 400k BTU; Intellibrite 120V pool and spa lights; Regular ol' plaster.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    It would be the longest point across, but only the longest point across that is generally a straight shot from one side to the other, i.e. nothing diagonal to get the numbers. So the way I'd measure your short dimension is from the middle of the lower left arc to the middle of the top right arc.
    So said another way - longest measurement a straight line forms in a lengthwise and width-wise direction. Ultimately the goal from their perspective is to make the pool sound as big as possible. An 18 x 38 free form pool is significantly smaller in volume than an 18 x 38 rectangle.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2016
    ada, mo
    32
    Thank you! It is difficult to tell with the picture. In person it looks like the left side of the pool is a lot smaller than the drawing. This is the only drawing they gave me. I will talk to him about my worries. Guess Im just nervous I want it to all go right.
    triptyx's Avatar
    Apr 2016
    1,438
    It does appear to maybe be a little bit smaller, but that could be the angle at which you're looking at it too!
    Here's the thing - if you don't like it, for whatever reason, now is the time to invite them back out to discuss it and respray it more like you want it! Spraypaint is easy to move (it may change your cost a little though, heads up!), the pool after it's built is forever.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Wishing you luck and following!
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    Hard to tell.. but looks like the drawing is the reverse of the paint.
    SunCountry
    South Phila PA area.
    Sundance Spa; Chelsea (468 gallons). Former 28ft AGP owner for 20 years.
