Thread: Help with algae/cloudiness
    May 2015
    Fairport, NY
    15
    We opened our pool about 2 weeks ago. Went to plug in the SWG and nothing. We contacted Intex, they sent us new one. In the meantime, we had been adding bleach to prevent it from turning green. Well one weekend at a softball tourney and 3 hot days...we lost the battle. More bleach and no longer green, but cloudy. Hubby is a big fan of pool stores...they told him to add aqua ok flocculent, and 2 bottles of shock. I said No! So here I am. New SWG is being hooked up today. I didn't want to play with water chemistry until that was functioning.
    What are my next steps, HELP?
    21', Above ground
    AGP, 21'round, 10400gal, sand filter, ConvertED Baq to SWG (intex)
    Jun 2011
    Long Beach, CA
    2,790
    Re: Help with algae/cloudiness
    The next step is the SLAM process, see my signature. You can start that without the SWG working. If you need guidance on the SLAM ask for help.
    You were right to stop the Hubby from going the pool store route!
