Cloudy water - Just need a gut check
Sep 23, 2015
36
Bloomington IN
First summer with pool. Opened crystal clear in April. Good all season.
Just last night started getting cloudy. I noticed my chlorine was low (almost zero). I chlorinate like the previous owner, pucks in the filter basket (I know, there’s debate on this method). I neglected to put a new puck in for a couple days.
I tested with my TF 100 kit today, my numbers are below. I added liquid bleach per the calculator (2.5 gal), put the safety cover back on and kept the pump running
I figured I wasn’t going to mess with any stabilizer or anything else right now, just shock it to get the FC back up.
Does this all sound correct?
FC = 1 (if that)
CC = 0
CYA = 30
CH = 500
TA= 55
pH = 6.8
It is true that the PH test is invalid when FC is above 10 ppm.
The test results in post #1 was 6.8 with FC 0
Enter your test results in Poolmath and target PH of 7.2.
Adjusting PH to 7.2 is one of the prerequisites of starting a SLAM. It is important to follow all of the steps in the SLAM process. More here, SLAM Process
