Thread: Intex Metal Frame Above Ground Pool Leaking Around Drain Outlet
    Jun 2016
    Saskatoon
    1
    We have leaks in the seams around the drain outlet and patching does not hold up long term because of the ridges in the seams. Is there a better solution to fixing up the leaks so they hold more permanently?
    Apr 2013
    Sacramento, CA
    2,769
    Re: Intex Metal Frame Above Ground Pool Leaking Around Drain Outlet
    WELCOME TO TFP !!!!!
    Can we get a picture?
    Is what you call a drain a skimmer along the top wall of your pool, a drain in the side of the pool or a drain in the pool floor?
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    I think they are talking about the actual drain at the bottom of the wall. It's reinforced like the other openings and has a plug on the inside and a cap on the outside. If so I'm not really sure if a patch would hold long there. It's on a spot of the pool that sees the most stress from water pressure. Being uneven with the different thickness of the reinforced area doesn't help.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Jul 2014
    Oakbank, Canada
    389
    I had same issue on my first pool, ended up gluing a very large patch over the entire drain area on the inside. Never used the drain anyways, always used a pump to empty the pool. Go to you local pool supply store, they usually sell liner patch by the square foot.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
