Page 1 of 2 12 LastLast
Results 1 to 20 of 39
Thread: New Intex dual suction outlet... please help
    Jun 2016
    Lake Elsinore, CA
    8
    I replaced my old 18ft ultra frame with a new one to replace liner since it was cheaper (bad idea). Well the new one has a "dual suction outlet" which makes connecting it the usual way difficult. Im not savvy on plumbing/pool "how to do's" and not understanding other posts on this same subject. Ive always used the larger hoses and used a small adapter for my Hayward pump since its a tad bit smaller. This pool has 2 outlets and are about 1 inch, I can cut the liner and make bigger like the other suggestions, thats not a problem but I dont understand the second port. Others have connected the hayward side skimmer, but I am afraid to cut a hole that big where I may damage or ruin the liner plus my pump only takes one hose. Im thinking capping it off is ideal... but will those little black rubber (plungers) hold and not disconnect. I need to get this pool going and open to your suggestions and opinions... Please I need help.
    Intex 48x18 Ultra Frame with NEW dual suction outlet, approx 6500 gallons, Hayward Power Flo Pump 40GPM w/micro star filter and basket (cant get lid off basket).
    Re: New Intex dual suction outlet... please help
    Did your new pool come with the little black rubber stoppers that look like a little hat? Those work to cap off the flow of water. I did this on one of my inlets to allow for better suction on my skimmer.
    18x52 Ultra Frame with 1600 gph sand filter and intex skimmer
    jmcdtucson's Avatar
    Jun 2014
    317
    Installing the skimmer is really not that difficult and I haven't heard anyone ruining their liner by doing it.
    Pictures would be helpful.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Jun 2015
    Stockholm, Sweden
    250
    I think this threads shows you exactly what to do: Side Wall Skimmer With Dual Inlet Liner
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jun 2016
    Lake Elsinore, CA
    8
    Reply to "I think this threads shows you exactly what to do: Side Wall Skimmer With Dual Inlet Liner"
    I dont have my pool set up with all the pvc piping... that looks like the inlet side. I see the two outlet ports but doesnt show anything else. How can you get two hoses on one pump... this doesnt make sense. Thank you for the reference
    Jun 2016
    Lake Elsinore, CA
    8
    Reply To "Did your new pool come with the little black rubber stoppers that look like a little hat? Those work to cap off the flow of water. I did this on one of my inlets to allow for better suction on my skimmer."
    Yes it did... which makes me believe this is my best option here. I dont understand two ports for hoses that need to be hooked up to 1 pump. Thank You
    Jun 2015
    Stockholm, Sweden
    250
    Didn't you get a plunger valve with two inputs?
    Jun 2016
    Lake Elsinore, CA
    8
    New Intex 1.jpgNew intex 2.jpgnew intex 3.jpg Here are the pictures. Ruining it would because id cut too big, leaks, and have nothing to hook it up to. Because I have nothing hard plumbed (is that the right term?) none of the examples Ive seen help me. I dont want those little hoses and then connect to make a "T figure" for my pump. I run a larger pump but it still only has 1 port for a connecting outlet hose. I have the little rubber stoppers, Im thinking this is my best bet to plug one port. Thanks for your response.
    Jun 2016
    Lake Elsinore, CA
    8
    Quote Originally Posted by Mickelin View Post
    I posted pictures of the manual of what I got, plus I took pic of outlet ports of my pool. Plunger value would be little rubber stoppers?
    Jun 2015
    Stockholm, Sweden
    250
    The plunger valve is the grey thing in the drawing that the grey hoses are connected to.
    Jun 2015
    Stockholm, Sweden
    250
    If you just want to get pool up and running and not hardplumb or add skimmer, all you need to do is connect the two smaller hoses to the plunger valve as shown in the picture and then run the one hose to the pump, just like your old pool. Not sure what the problem is?
    Jul 2015
    Charter Oak, California
    273
    There are two outlet lines (ports or holes) from the pool to the pump for legal reasons. Two outlets splits the suction of each port in half. That makes it less likely that a young child could be held below the water line. Regardless..
    Your pool kit came with a plunger valve that the two hose lines from the pool connect to. It's called a split plunger valve. Then from that connection, out from the bottom of the split plunger valve, one single hose goes to the pump. Just like in the diagram.
    The black plug/cap you're talking about comes with your pool kit and goes on the inside of the pool on one of strainers on one of the suction lines. Then only one of the outlet ports actually sucks water from the pool, through the plunger valve and to the pump. There really isn't much difference in how water is circulated, regardless of the size of your pump whether there are two suction lines or one. (Except of course, the relative safety it provides by splitting the pumps suction between two hose lines in the pool instead of a single suction line.)
    Having the suction split into two hoses at the pool affects your ability to vacuum efficiently. Or, if you attach a skimmer and have two outlets the skimmer will be less efficient.
    The two hoses from the pool, to the plunger valve, to the pump work the same as one line from the pool to the pump.
    If your not going to use the two suction lines and the hoses at all and you're going to cut in a through wall skimmer, then, the black plugs/caps need to be used to plug the two small suction lines.
    May an amateur pool owner make a suggestion? Maybe you could set it up as the instructions say, make sure everything works, see what the two suction lines do, and then make any plumbing changes you want sometime after that? It seems it's not that difficult to make changes while the pool has water in it....
    Bob (AKA Schnozz)
    12 x 24 x 52 Intex Ultra Frame AGP, 8600 Gal; Pentair 2HP/2SP 150sqft Cartridge Filter; Hayward Through Wall Skimmer; Intex Automatic Cleaner (Fantastic); K-2006 Test Kit; Start-up 07/30/2015. First Time Pool Owner in SoCal.
    Jun 2016
    Lake Elsinore, CA
    8
    Because I don't want to use the little small hoses, rather use the larger in diameter... For Water flow. Of course I can set it up like the pic, that's not a problem. I'm plugging the other side I don't see any other way. Thank you.
    Jun 2016
    Lake Elsinore, CA
    8
    Quote Originally Posted by Schnozz View Post
    Thank you. Your pool is bigger Than mine and if Your not having problems with water flow then I guess this option isn't to bad. Because our summers are really hot im afraid that the 2 small hoses wernt enough water flow. I can zip tie the splitter in place (yours looks in place) so my dogs dont get tangled in the T figure. Hope over the summer I'll be able to understand the strainer part and how too hook it up, maybe they have the 2 inch splitter "plunger valve" like the smaller ones they include (I have several 2 inch single plunger valves).
    Thank you for your detailed response, I appreciate it.
    Jun 2015
    Stockholm, Sweden
    250
    If you plug one of the existing outlets you will get less flow, not more. (Half, in fact). If you want better flow through larger hoses you need to get the larger strainers Large Strainer - Intex and cut larger holes. You either plug one of the outlets and run one hose to the pump or you replace the plunger valve with a T.
    Jun 2016
    Lake Elsinore, CA
    8
    I have that same strainer from my other pool... I am going to use that one, cut a hole and plug the other side. Until I can find an Intex T plunger valve for the larger hose Im stuck... at that point I can add the Hayward strainer everyone is talking about. Thanks for all the help...Im adding water tonight.
    Jul 2015
    Port Neches, TX
    53
    We upgraded our pump and hoses to the larger ones buy buying stuff from Amazon. We bought these Amazon.com: Intex Pool Strainer and Inlet Assembly Kit for Large Above Ground Pools: Patio, Lawn Garden it comes with one inlet and one outlet strainer. They also sell the outlet strainers separately here, with the plunger.
    Then you just cut the holes a little larger and attach these plunger valves so you can stop the flow of water into the pump to clean the cartridge, etc. Amazon.com : Intex 10747 Large Pool Plunger Valve Assembly : Swimming Pool Pump Accessories : Patio, Lawn Garden
    22' x 52" Intex UltraFrame ABG, 10,500 gallons
    using TF-100 test kit
    Krystal Klear 633T Filter Type B pump - 2,500 GPH
    Intex wall-mount surface skimmer
    May 2017
    Las Vegas
    6
    Does anyone know the size of the 2 black stubby things coming out of the 24x12x52 new liner? Are there any close up pics so I can see how they're attached?
    May 2016
    Minot, ND
    11
    I know the intex 1 1/4 fits over the black tubing and it is secured with a standard hose clamp that screws tight over it.
    IMG_6751.jpgHere is a pic of mine
    Trying to live the easy life :-)
    Intex AGP 18X9X52; Intex Sandfilter/Pump; Index Salt Water System
  20. Back To Top    #20
    May 2017
    Las Vegas
    6
    Thanks for the reply. Doesn't the outside hose and clamp smash the black rubber thing? And what about that 2 way plunger? What size is that bottom hose? That is going to your pump right?
