Results 1 to 10 of 10
Thread: help understanding test results
    velorajodene's Avatar
    Jun 2016
    Seattle WA
    9
    Hi again, so as suggested in my last post, I ordered just the FAS/DPD portion of the test kit. The rest of my numbers of from HTH 6 way kit. It's been raining a lot lately so have had the pool covered and been adding about 1/2 gallon bleach daily while waiting for kit. I've been running the pump for about 4-8 hrs per day. I just uncovered the pool and did all the tests. Here are my current numbers.
    FC 27
    CC .5
    PH7.8
    TA 1000 + (i got to 100 drops then stopped because it remained yellow.
    CH 0 (turned yellow with the 5 drops)
    CYA 30+ (It got to the top of the tube when i could no longer see the dot).
    I don't really know where to go from here because I'm not sure if I should have kept adding to the TA or if it is sky high and useless. Please advise. Thank you so much
    Lori
    Orting, WA
    5500 gal. AG,8' by 48" AG,cartridge filter , type c, polygroup
    rx 1000 pump, 1single speed,install 6-8-16
    hth 6 way test kit,TF-100 ordered, city water, no restrictions
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: help understanding test results
    If the CYA test went to the top of the tube before the dot was obscured, you are more likely at <20 CYA. If your FC test is accurate, that is way high for that CYA. I wouldn't add anything to the pool for at least a day.
    How does the water look?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2016
    Seattle WA
    9
    The water looks clear. Thank you for the quick reply.
    Orting, WA
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Something is wrong with the TA test. I am not familiar with the HTH kit (Yellow for TA?). But I have never heard of a TA that high. Can you tell us the instructions on the HTH kit how you went about that?
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jun 2016
    Seattle WA
    9
    Sure, Add 5 drops alkalinity indicator, swirl, should turn green then add titrant drop at a time and count drops until it turns red. It turned yellow, but never red, I didn't want to waste solution so I stopped. I could do the test again, maybe I did something wrong?
    OK, just did the test again, apparently , I did it wrong, this time the result was 150.
    Orting, WA
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    That makes more sense. Went from green to red correct? Never Yellow - Right?
    Jun 2016
    Seattle WA
    9
    That's right
    Orting, WA
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    I just looked up the HTH kit on Walmart. Even though there's really no decent info in the description, I see there are only 2 vials in the kit that have green caps (usually an indication of the vials used for the TA)... I take it there is no Thiosulfate in that kit?
    That is usually the first thing you want to add prior to a TA test to neutralize the chlorine. Being that your FC is quite high right now you probably were working with a funky green color after adding the indicator (the vial that turns the solution green).
    When FC comes back to earth, try testing your TA again. I bet you will get a better contrast of the green to red change.
    Also your pH reading may be off because of testing in a high chlorine sample. Not that there's anything wrong with a 7.8 pH. But you should test that again when chlorine lowers.
    Jun 2016
    Seattle WA
    9
    Thank you mikemass, I will do that. I plan to get the TF-100 kit as soon as my Husband calms down, I made a few unnecessary purchases when we first bought the pool, before I discovered this site so he is not so keen on me spending more at the time. It's easy for me to see that I will reach a dead end soon and really need the kit but need to wait a bit. I appreciate all the help, this has been an invaluable site for me.
    Orting, WA
    Jun 2016
    Seattle WA
    9
    I've had the pool uncovered for the past 2 days now and it's rained a bit here. I vacuumed the bottom and tested the water this morning. Here are the numbers.
    FC 17.5
    CC 0
    PH 7.5
    TA 150
    CH 0
    CYA 40
    Other than the hight FC I think it's doing well. I've run out of CYA reagent again but the good news is, I ordered the TF 100 kit along with extra CYA and the stir thingy. I'm excited for it to get here. Water looks crystal clear and the weather is supposed to be warm enough to swim today. YAY! Happy Father's day everyone and thank you all for the helpful advise. I'm addicted to this site.
    Orting, WA
