Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: In need of a lot of help
    Apr 2016
    Tucson AZ
    19
    My pool is green I'm pretty sure I had a algae bloom and I'm pretty sure I have black algae here are my readings
    Temp 81
    Fc 4.5
    Cc 0.5
    Ph 7.4
    Ta 130
    CYA >100
    I'm assuming I need to drain probably half the pool to drop CYA then get the pool ph to SLAM levels...
    20k gal, kidney shaped plaster, Hayward pro series s2442 sand filter, Hayward vari-flow valve, and a 1972 swim epuip XL-VI pump, Taylor K-2006 test kit.
    Jun 2014
    14,990
    Re: In need of a lot of help
    Hello and welcome to TFP! You are correct. Lowering that CYA is #1 right now. Being in Tucson, you might normally appreciate an elevated CYA like me, but for a SLAM perhaps not so much. But if you can get it down to at least 50 that would be a decent place to be. Once you get the CYA lowered, post some new results and we'll help you form there. Great to have you with us.
    Apr 2016
    Tucson AZ
    19
    while i am draining the pool should i brush also to try and get some of the algaeto drain?
    Jun 2014
    14,990
    That will be fine. Just be cautious to not overwhelm the drain to cause a potential clog. But the more of the junk you can remove now the better.
    Apr 2016
    Tucson AZ
    19
    alright...i cannot actually convince myself to drain 50% of my water on top of the fact i dont have a sump pump how ever i did drop the pool 1/4 ish and then refilled and retested my cya is now about 90 (yes i know impractical but i can spend the extra money on chlorine vs water/elec and fines...) Btw im hitting monsoon season so hopefully that will drop my CYA over time. i am currently keeping my pool at an FC of 60 for mustard algae but i dont know if its mustard or not
    Apr 2016
    Tucson AZ
    19
    This is what it looked like at about 1100 before drain and refill
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    That pool looks barely green compared to most of the swamps we see! What makes you feel you have mustard algae?
    We do NOT advocate tossing in mass quantities of chlorine in the false hope that it will fix what ails you. More often than not it just causes the FC to disappear faster and its harsh on the pool and equipment.
    Please review this: FC/CYA Chart
    Apr 2016
    Tucson AZ
    19
    1st indicator was the color change in the plaster then when I started adding chlorine it would go cloudy the next day but never clear up then the green started to appear and as I swept their were visible clouds of yellow then turn to green that was when I was keeping the fc at about 3...I just recently got the k-2006 so I never knew my CYA now that I do I figured I would treat the algae
    Apr 2016
    Tucson AZ
    19
    Did I screw up? Could it just be copper?
    Jun 2014
    14,990
    In Tucson, it shouldn't be copper unless you repeatedly added some pool store products in the past like algaecides. From the pic it just looks like regular algae really. By TFP standards, even if it was mustard algae, the treatment here is the same - regular SLAM/Shock FC level and pass the 3 SLAM criteria first. Only then do you increase FC to MA level and only for 24 hours. So I would let your FC fall to the appropriate SLAM level based on the Chlorine./CYA Chart. That way you don't waste bleach and $$. A successful SLAM really depends on consistency and doing everything on that SLAM page. Just takes some time. Your pool is not the worse we've seen, so hopefully you'll get through this in good time.
    Apr 2016
    Tucson AZ
    19
    Jun 2014
    14,990
    Stay with it! That looks just like regular-old algae from here. Just be sure to maintain the FC based on your CYA. No need to blast it right now. The only thing I would say is be absolutely sure of that CYA when testing outdoors to ensure you do in-fact have a the right FC SLAM level. Other than that, lots of patience I'm afraid. Having a nice pool like that, and with summer officially starting tomorrow, that's probably difficult to do.
    Apr 2016
    Tucson AZ
    19
    It's not so much me that needs the patience it's the wife and kids...in checking the fc and cya about every hour to 1.5 fc is currently 39 which is where is needs to be according to chart but that means it dropped 30 fc in about 8 hour's
    Jun 2014
    14,990
    You are in a tough spot wit that high CYA, but I understand your reasons locally. CYA of 90 means an FC of 35. Hopefully you're last test was accurate so you will make the gains expected with a SLAM. That would be my only concern. Just in case ... if you don't see better gains in the next day or two, maybe consider a diluted CYA test as follows:
    Add pool water to bottom of sticker.
    Add tap water to top of sticker.
    Shake.
    Pour out half so mixture is to bottom of sticker.
    Add reagent to top of sticker.
    Shake.
    Test outside with back to sun and tube at waist level.
    Pour back and forth a few times to see if you get the same result.
    Double the result.
    Good luck!
    Apr 2016
    Tucson AZ
    19
    I actually did it last night but I didn't have the right lighting and I was near 50-60...I'll do it on my next test and post results
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Copper isn't cloudy, it is clear like green koolaid and it doesn't brush up a cloud. That is definitely some algae.
    Apr 2016
    Tucson AZ
    19
    Thanks for the clarification pooldv
    Apr 2016
    Tucson AZ
    19
    When I vacuum should I put it to waste or filter? since my CYA is so high could it (waste), in theory, help lower my CYA as I have to replace the water that has been dumped?
    Jun 2014
    14,990
    Yes. It might take several attempts over time, but absolutely. At this point every little bit should help.
  20. Back To Top    #20
    Apr 2016
    Tucson AZ
    19
    Soo pool is clear (not as beautiful as everyone else's but it will get there)...and I lost less then 1.0 ppm last night
