Thread: Stenner Pump Maintenance / Installation / Recomendations
    Mar 2016
    Easley, SC
    380
    I have finally decided to go the stenner route instead of using the dosatron. The biggest reason for my decision is I found one on craigslist for $50. Its an 85MHP17 adjustable. I should have it in hand today but I have seen videos of it working so I am not too concerned about that. It was used to chlorinate drinking water that was being pumped from a lake.
    My first question is, what should I do once I receive it to make sure it is in good working order? I have read about the index plate replacement and hose replacement. Anything else I should look at before I install it? What is the best hose to use in the pump and for the suction and return line? Anything I should oil/grease? Any advice from your experience would be greatly appreciated.
    My second question is, I can mount the pump either outside or under my house. I have a 5 foot crawl space with access right beside my pool equipment. I was thinking route the hose thru the wall to under the house from the tank outside (or keep a tank under the house?) and then back thru the wall to the return line for the pool. Would this be better than leaving it outside? Does anyone see any reason not to do this?
    18x36 inground / 28k gal / Phanton vinyl liner (replaced in 2009) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump
    Mar 2016
    Easley, SC
    380
    Re: Stenner Pump Maintenance / Installation / Recomendations
    I guess I am on my own with this one. I received it Friday and realized I need the check valve. I will probably go ahead and replace the hose and take a look at the disk inside.
    Apr 2016
    Rockville MD
    43
    If you can protect the pump and tank from the elements, and it's still easy to get at, then do that. Most people use the 1/4" chemical resistant black tubing. Will you be using a timer? You would need easy access to that as well. If it were me, I'd want everything positioned in a way so i can quickly eyeball everything for leaks or other problems.
    20x35 in-ground oval. Wet Edge Luna Quartz finish. Hayes Super Pump with AO Smith V-Green 165 VS motor. Polaris 380. Enersol solar heating with automatic controller. Automated chlorination with Stenner pump.
    Mar 2016
    Easley, SC
    380
    I keep my brush, vacuum, nets, etc under the house and thats where I would put the stenner pump. I plan to bury the chlorine tank to keep it cool and out of the sun. I am still searching for a timer, looking at a dual timer by intermatic as I currently do not have a timer on the pool pump either. That would be mounted outside the house for easy access to turn things on and off without going under the house. I was just thinking the pump may last longer if kept under the house. I thought about placing the chlorine tank under the house but afraid of fumes getting into the house from the tank.
    poolnewbies5874's Avatar
    Aug 2015
    SW Ohio
    124
    Quote Originally Posted by joshua5438 View Post
    We keep our pump and tank in our basement and then run the line outside. We have not had any problems with fumes.
    12,000 gallon Blue Hawaiian 'Hamilton' fiberglass IG 15x34 freeform, Pebble Beach finish, Pentair Clean & Clear 100 filter cartridge, Pentair SuperFlo 1.5HP pump, Stenner pump, Raypak 266k heater
    8/2015 pool build photos TFT-100 test kit
    Mar 2016
    Easley, SC
    380
    I may go this route instead of digging a big hole next to my pool pad. Will just have to see how easy it is to fill it under the house.
