Thread: Replacing broken weir door
    I've read a bunch of posts on this subject, yet following through with sources mentioned I don't see an exact match and don't know enough about weir doors to understand how exact of a match is needed , so I was hoping you guys might have some wisdom to pass along. Attached are some pictures ( I hope ) . Even the pool supply store had no answers. Thx so much in advance this forum is just the bestest and I can't imagine owning a pool without access to so much knowledge !!!
    Stump's Avatar
    Jul 2013
    Oklahoma
    143
    Re: Replacing broken weir door
    If you remove the foam is there a part#?
    Also check skimmer main body for part#
    24' Reprieve RD/AG/13K gal Vinyl TFP method
    Waterway Clearwater 175 sqft Cartridge
    Hayward Power-Flo Matrix 1HP Pump 2-Speed
    TF-100 Test Kit SpeedStir Borate Insta Test
    Spreading TFP to All
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    The critical dimension is the width, so that it stays in place. The height is fine as long as it's close to the original. The closest match that will work would be Pentair Weir Assembly (516252) - INYOPools.com
    Is there a part number on the underside of the skimmer, say for instance if you remove the foam, do you see a part number underneath it? If you can find that part number or the skimmer part number, call inyo pools about it and they can help you out too.
    Isolated Spa - 345 Gallons
    Stump's Avatar
    Jul 2013
    Oklahoma
    143
    This appears to be exactly like your broken weir except for size. At inyopool.com this PART# Hayward Weir, Skimmer (spx1089k) - INYOPools.com
    Maybe a call to Hayward can get your replacement.
    Part number.. That would help.. I didn't see one (which struck me as odd ) but didn't think about under the foam. Will check when I get home. While all of these look like options , my concern was the pivot hole. Seems to me like something that needs to match. Thanks so much for all the replies!!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    The mfg info is often on the underside of the skimmer lid.
