Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: TF-100 CYA control test issues
    Nov 2015
    Wilmington NC
    7
    The control sample that came with my TF kit seems to test closer to 30ppm. I can clearly see the dot still at 50ppm. On the plus side, the kit allowed me to determine that my CYA is the cause of my algae issues, as it is off the charts. I will be draining to clean some existing staining anyway, but I was a bit concerned that my very first test (using the control sample) seemed so far off. Is this common?
    Thanks!
    Adam
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,250
    Re: TF-100 CYA control test issues
    Some people get better results with the glance method. Look away from the tube, then glance at it. Look away, glance again. If you see the dot, keep adding, but if you don't see it with a glance, you're there.
    Great that you have the standard. That provides a way to fine-tune your method. And don't be alarmed, everyone finds the CYA test to be a bit tricky.
    Also, you can pour the test solution back into the mixing bottle, give it a shake and then test again. Some people do it three times and have a better idea.
    There's a few other tips as well. Have the sun to your back, hold the tube in the shade at waist height and look down. Be sure your sample is warm enough, but I'm guessing that isn't an issue just now. It should be around 75 or warmer.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Sep 2015
    Rome, NY
    363
    My control read 40 to me.
    I was testing at 50.
    So I shoot for 5.0 FC and call it a day.
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    Nov 2015
    Wilmington NC
    7
    Thanks all. Yes, the dot is VERY clearly visible whether glancing or staring, regardless of distance or lighting. It's just plainly visible until 30ppm. There is nothing else I can really say. I can take pics to show what I am seeing, but I have seen pics online of obscured dots, and I am very confident that I know what to look for. My pool sample completely obscured the dot well before reaching 100 even. Regardless, I know now that a drain is absolutely required, so the test kit was well worth the investment. Strips were really lying to me about my CYA.
    Mar 2016
    Chicago,IL
    88
    Quote Originally Posted by Stockhatch View Post
    Thanks!
    Adam
    Your tf kit came with a control sample?
    19k 15x36' inground oval vinyl lined pool with deep end. 3 returns , 1 skimmer, 1 main drain. TF-100 test kit
    Nov 2015
    Wilmington NC
    7
    Maybe it was an option, but yes, it came with a sample that is supposed to read 50ppm +/-5ppm.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Bullet #8 that is in the "what's included" section:
    R-7065 CYA Standard Solution test-Over the years we have found that testing for CYA is often times confusing to many individuals. R-7065 is basically pool water with a result of 50 ppm CYA. It allows you to test the effectiveness of your R-0013 and to ensure you are using proper testing techniques
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    JoyfulNoise's Avatar
    May 2015
    13,213
    Quote Originally Posted by Countpyro1 View Post
    This is a new offering from TFTestKits. The newest version of the TF-100 comes with a few test's worth of the R-7065 solution which is a 50ppm CYA standard. I believe this newly modified kit has been shipping for the last month or so.
    Matt
    Apr 2015
    South Central PA
    297
    Make sure you shake both the R0013 and the R7065 before use....I definitely notice a difference. I was getting the same ~30 CY with the benchmark. I did a test immediately after this, but shaking both solutions well, and it came in close to 50....whether it SHOULD make a difference or not, I don't know, but it did for me....
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Thanks for the feedback.
    Yes, as Matt indicated, it is a new feature, upgrade to the TF-100 in the last month or so. The theory of the sample is that, if mixed and tested properly, this is a known 50 ppm sample. This is what 50 ppm of CYA looks like. Train your eye to look for this end point in the test. TFTestkits is rolling out some samples to some folks so we can better understand how it works and how to help people with it.
    Here are some reference photos of the test from Taylor
    https://www.taylortechnologies.com/C...P?ContentID=36
    May 2015
    13,213
    By the way, the correct way to use this standard is to make up the mixture with the R-0013 and then fill the view tube to the 50ppm mark. Then you go around your property or house and find the correct lighting and viewing conditions that makes the dot disappear. Then, when you actually test your pool water, you use the same conditions from the test.
    Matt
    Nov 2015
    Wilmington NC
    7
    I'll try again after shaking the sample up well. The dot would have been visible in any light conditions. It looked very close to "mid test" in that example picture. I am in the process of acid cleaning the pool and converting to SWCG, so it will be a little while before I can test my pool water again.
    FattyLumpkin's Avatar
    May 2016
    Massachusetts
    188
    Thanks for this. I have struggled between seeing what I *think* is the dot and what are actually reflections / shadows on the inside of the vial. I'm going to try this today, as I think it's purely lighting related.
    / 24k Gal, 18x36 Freeform IG Vinyl Saltwater / Sta-Rite MPRA6E-205L 1HP Pump / Sta-Rite System:3 Cartridge Filter / IC-40 SWCG / Dolphin Nautilus Cleaner / TF-100 Test Kit w/ SpeedStir / Taylor K-1766 Salt Test /
    Useful Links: Recommended Levels / SLAM / FC/CYA Chart / Test Kits Compared / Edit Your Signature
    Sep 2015
    Rome, NY
    363
    Good idea. Now I need to try this
    May 2016
    Harford County, MD
    27
    I was going to create my own thread and then found this one which sums up my issues quite nicely. I hope everyone doesn't mind if I piggyback. I too am having issues with inconsistency even with the standard. Below are some pics with R-7065, which I based on my testing read 25. The pics in order are: visible dot at 55, visible dot at 50, visible dot at 45, and the last two show a vanished dot (even though I can still slightly make it out) and the corresponding reading. I know lighting is not an issue. My backyard is shaded in the evenings when this test was done and it was cloudy out. Perhaps I'm doing the test incorrectly. The instructions say mix and wait 30 seconds. I've seen elsewhere where you actually mix for 30 seconds. Which is it? I have no clue what my pool CYA is as I've blown through the R-0013 and R-7065 trying to get this right. Any suggestions would be appreciated.
    ~23K gal IG plaster, Pentair Superflo VS, Leslie's Crystal Clear II (Hayward Micro-Clear DE4800) filter, TF-100 Test Kit
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    swing4terps - I agree 100% with your assessment. Great clarity on the pics. Without a doubt the first 3 clearly show the dot. It is my understanding that you shake for 30 seconds. That is directly from my genuine Taylor kit instruction card:
    needsajet's Avatar
    Jan 2016
    4,250
    For me, when I decide to test for CYA, I mix it up first. Shake for 30 seconds, then stick it in my pocket. Then I complete whichever other tests I plan to do. Then pull out the CYA bottle and shake it a bit, then do the test. Works for me, but I can't speak for this as a recommended method, other than to say I read it here and no one said it was a bad idea.
    38,301
    swing4terps - couple notes:
    - The lighting does not look bright enough (no sun out?)
    - You should try holding the vial at the very top with only 2 fingers so that more light can hit the solution.
    That said, it seems that just about everyone gets a reading closer to 40 than 50, unfortunately.
    May 2016
    Harford County, MD
    27
    Oh, I always thought the idea what to eliminate any sunlight while doing the test hence turning your back to the sun. I guess I will need to buy more R-7065 and R-0013 and try these alternative methods.
  20. Back To Top    #20
    needsajet's Avatar
    Jan 2016
    4,250
    Yeh, what Jason said just turned on the lightbulb for me too. The lighting needs to be bright enough to light up the particles floating around so they obscure the dot!! But not super bright direct sun which wouldn't work. Thanks so much!!!
