Hi, this is my first post. This is my fourth summer as a pool owner, and this site has been an immeasurable tool in learning to care for my pool. I will try to be brief in my back story of my problem: Last year pool was left uncovered due to old cover damage and not replacing during winter season. We were left with green swamp for which we sought assistance at local pool store. Fast forward after multiple algae treatments, unnecessary chemicals, etc later, and pool was still green. Consulted your site, determined we had possible copper contamination, treated with sequestrants, cleared green color, maintained with BBB and tri-chlor tabs through end of last summer. This year after new cover not properly fitting, allowing rain, leaves etc into pool, we were again facing a green swamp, however, with all my new knowledge from this site, I was sure I could resurrect pool with no problem. Used BBB with SLAM method, vacuumed, etc. Pool still green. Added sequestrants, pool progressed to blue/green, then aqua, then baby blue. I allowed CL to trend to 0 while treating CL. As soon as I reintroduced cl, blue/green returned. Total of 12 bottles of sequestrant (over 2 treatments) and allowing cl to reach 0, I was left with cloudy, but visible to bottom of deep end pool on 6/8/16. Began adding Cl and adjusting ph levels, etc and water became cloudy with blue tinge. Thought I may have allowed some algae growth with low cl level, so rose CL to 12 per pool math and water immediately turned bright blue. We added 2 packs CU later on 6/15 thinking maybe the HTH metal out we used was not effective enough. No change in color. My numbers as of 6/17/16 7am are as follows:
CL 12.5
CC</=.5
ph 7.2-know this is a little low, havent gotten to store for more Borax
TA110
CH-Test turned purple, never turned red, then turned blue at 80ppm, then immediately back to purple.
CYA-out of reagent, but added 9# based on pool math on 6/12 after test showing essentially 0. Haven't vac, etc and CL is losing ~1-1.5 ppm in 24 hours(if that helps)
We bought T2006 this year and have only added HTH Metal Out, HTH floc and HTH Clarifier outside of the WM 10% liquid chlorine, Arm and Hammer Backing soda, and 20 mule team borax chemicals. Our chlorine pucks are Doheny's Tri-chlor. We are on city water.
Based on everything I have read, the fact that water clears when Metal Out is introduced and CL levels are low has me believing this is Copper (which I believe came from all the pool store algaecides I was sold last year (regular, mustard, different brands, etc).
What am I missing??? Can the sequestrant be that ineffective in keeping Cu bound?? I don't trust the pool store people enough to even have Cu levels run
Thanks for all your help and suggestions!!
CL 12.5
CC</=.5
TA110
