Results 1 to 14 of 14
Thread: Blue but cloudy water
    May 2013
    Omaha/NE
    8
    Having trouble figuring out what is happening. Opened pool late this year due to broken pump and waited for part. Been shocking the snot out of it for a week and water is still cloudy. Started the SLAM technique the other day but not seeing any results yet.
    26ft Round Above-ground
    12000 Gal
    SWG
    FC- 10+
    CC -
    Ph- 7.2
    TA- 90
    TH- 150
    CYA - 30
    Salt- 3400
    12K AG, Vinyl Round Pool, Sand Filter, Pentair SWG, Doughboy Power-line Pump-HP 1.5, Omaha/ NE
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Blue but cloudy water
    Hi, welcome!
    First of all what test kit are you using? If you could add that to your signature (thanks for filling out your pool info!) that would be awesome.
    Also, if you could put your location in that would be great too.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    May 2013
    Omaha/NE
    8
    Taylor K-2006 test kit
    Taylor saltwater test kit
    Location is Omaha, NE if that's what your looking for
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Great!
    Some SLAMS take 2-3 weeks. If you started "the other day" you might just need some time.
    How often are you testing and adding FC? Brushing at least once a day? CC would be a good number to track.
    May 2013
    Omaha/NE
    8
    Tested FC this am but it seemed to be so high so I didn't do a complete FC/CC test (didn't want to use all my test chemicals) hopefully it will drop a bit during the day that I could track CC tonight
    May 2013
    Omaha/NE
    8
    Quote Originally Posted by Mr Bruce View Post
    Great!
    Thanks for the quick Responses BTW!
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    No problem.
    You may want to read the SLAM article again Pool School - SLAM - Shock Level And Maintain
    Here are some highlights:
    You want to bring FC to the SLAM level for your CYA, which is 12 (not 10+ )
    You want to test more than twice a day and less than once an hour.
    CC that's just 5 drops of 003 (? memory) and a few drops of 871?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,176
    For your SLAM you should be targeting 12FC. You should be testing and using Pool Math to calculate additions of chlorine. Don't add so much that you end up with chlorine levels that "seemed to be so high so I didn't do a complete FC/CC test". We call this nuclear additions of chlorine. "Nuking" the pool with large amounts of chlorine ends up wasting much of the chlorine as it burns off in the sun quicker and can damage pool parts, especially vinyl pool liners.
    Try to stick with calculated doses of chlorine.
    Support the site
    May 2013
    Omaha/NE
    8
    Ok I do have a SWG, why does it say in the SLAM that my Shock level should be anywhere from 24-31 depending on my CYA level?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    This chart is the foundation. I recommend often that people print it out and leave it where they test. I have it taped to the inside cabinet door. It's very important to understand and use Pool School - Chlorine / CYA Chart
    Please let us know if the chart doesn't make sense
    You should turn your SWG off for the duration of the SLAM also.
    May 2014
    Franklin, NC
    9,176
    Quote Originally Posted by bfuhrman7 View Post
    That is the general Recommended Levels Chart which includes pH, TA, CH etc., for chlorine we have a very specific chart - Pool School - Chlorine / CYA Chart
    Support the site
    May 2013
    Omaha/NE
    8
    UPDATE -
    Got home and tested
    FC- 4
    CC- 1
    PH- 7.0
    TA- 100
    CH- 175
    CA- 30
    NACL- 3400
    12000 Gal round
    SWG- Off
    Omaha NE
    Still cloudy and In the process of SLAMing, should I add more liquid chlorine tonight?
    May 2013
    Omaha/NE
    8
    Here is an example of what the water color and cloudiness looks like
    May 2013
    Omaha/NE
    8
    ANOTHER UPDATE on my SLAM - Thanks for any advice or encouragement
    FC - 10
    CC - 1
    PH - 7.2
    TA - 100
    CH - 150
    CYA - 40
    NACL - 3400
    FC was up but my CYA was up from last time probably because I had recently dropped this in the skimmer the other day. So according to POOL SCHOOL i needed to up FC to 16ppm so I did that with LC before coming in for the evening. Still cloudy (i know this wont change instantly) will check results in the AM and update here.
