Results 1 to 13 of 13
Thread: First TF-100 Test Results- Now What?
    Jun 2016
    Spencer, NY
    8
    Hi all, I'm a new member here and also a first time owner of a test kit which happens to be a TF-100 that I ordered after seeing it here. In the past we relied on the pool store to test our water and supply us with what they told us we needed. We have decided to take more of a hands-on approach to maintaining our pool in order to potentially limit the wide array of chemicals that we have used in the past.
    I believe that the following test results are spot on however a person with experience may notice something doesn't add up and have some advice for me. Please feel free as any input is welcome!
    FC= .5
    PH= 7.5
    TA= 160
    CH= 125
    CYA= 0
    Being new to this game, other than raising the CYA I'm really confused on how to move forward. How do I raise the CYA and how much product do I need for a 16,000gal pool?
    Thank you,
    Jeff
    18x33 (16,000gal) Vinyl
    Reclaimed Esther Williams
    2015 Hayward DE filter and pump system
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    496
    Re: First TF-100 Test Results- Now What?
    You can get CYA at Lowes or Walmart or the pool store. It is also called stabilizer but if you look at the ingredients you will see 96 or 100% cyanuric acid. You will want about 3 lbs to get your pool to around 30 which is about where you want to be. Add it in a sock in front of a return and base your chlorine levels on your target CYA but realize it won't show up on a test for a week or so.
    Is the water clear?
    If so get your chlorine up to around 3 PPM and don't let it fall below that.
    Your TA is a bit high but i will let someone else address it as i have always had stable TA and never messed with it so i can't help with it.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    There is a great little guide in Pool School: http://www.troublefreepool.com/conte...tal-alkalinity
    Jun 2014
    15,255
    Jeff, welcome to TFP! You've made a very wise choice with that TF-100. I think SoF's question about your current water condition will drive what you do next. If your water is crystal clear with no hints of cloudiness or algae, then sure, raise FC to at least 3 ppm, ideal target around 4, and keep your pH in that same mid-7 range. The CYA will also be increased as well. If your water is cloudy however and we suspect a "SLAM" will be required, then you'll first lower pH to about 7.2 then increase CYA to 30, and FC to "12" and maintain that FC until you pass the 3 SLAM criteria.
    So one of those paths will be for you based on your water condition. And if ever in doubt about algae, you can perform am overnight (OCLT) test as well.
    When you are ready to try and lower TA, you'll do so using the acid/aeration method as noted on the TFP Pool School - Lower Total Alkalinity page.
    Have a great day!
    Jun 2016
    Spencer, NY
    8
    Thanks for the quick replies folks! I really appreciate all of your guidance and will also review the links that you have shared.
    The water clarity is slightly off, does this automatically warrant a SLAM or would I be better off performing an OCLT tonight?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    I would raise FC to 3 immediately. I would get some CYA in there, shoot for 20-25. Then around sundown, raise the FC to 10. Confirm in 30 minutes. Then test it in the morning before the sun comes up.
    Water clarity "slightly off" means different things to different people
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2016
    Spencer, NY
    8
    Received, thank you Sir!
    "Water clarity "slightly off" means different things to different people " I suppose THAT'S a valid point!
    Sep 2015
    Rome, NY
    363
    Good luck.
    Read all the links in signatures and use the calculator.
    Post updates and all will be good
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    Jun 2016
    Spencer, NY
    8
    OK folks, with the help that I've received here our pool water is nice and clear and looking great and we are very thankful! Chemistry was never one of my strong points years ago and I'm starting to remember why...
    Below are our latest test readings, now what and how?
    FC= .5
    CC= 2.5
    PH= 7.3
    TA= 170
    CYA= 30
    Aug 2014
    Northern IL
    4,615
    Looks like your water is ready for a SLAM. Here's how:
    Pool School - SLAM - Shock Level And Maintain
    Do you know how to use PoolMath? Here's another how:
    Pool School - PoolMath
    Jun 2016
    Spencer, NY
    8
    Quote Originally Posted by MarianParoo View Post
    So even though the water is crystal clear it still requires a SLAM in order to balance it?
    I think I'm getting a handle on PoolMath, can all of the recommended chemicals be added at the same time or is there a sequence that needs to be followed?
    Thanks!
    Aug 2014
    Northern IL
    4,615
    Yes. Did you see in the slam article how your CC needs to be 0.5 or less?
    The only chemical you need to add now is chlorine. You need to get your FC up to 12 and keep it there as often as possible. After your slam you can deal with the TA.
    Jun 2016
    Spencer, NY
    8
    Got it, thank you!
