Results 1 to 8 of 8
Thread: Using Taylor K-2006C Test Kit
    Nov 2014
    United Kingdom
    220
    I have just received my test kit
    I can't see how to test for Cyanuric acid down to 20ppm as it is only graduated down to 30ppm
    10,000 gallons inground Leisure fibreglass pool, Hayward powerline pump, Quality120 glass media filter, 27kw output air source heat pump and thermal cover.
    Retractable cover with Polycarbonate roof and glass side for all year round use. K-2006C test kit and Speed stir
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Using Taylor K-2006C Test Kit
    If it completely clear filled to the top, you can assume there is none. If it's a little hazy, you might have 10-20.
    What do you see when you fill the tube?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I would keep CYA at 30 so that it can be verified.
    Nov 2014
    United Kingdom
    220
    I haven't filled it yet, I was waiting to see what answers I got before attempting
    I have a Retractable cover with Polycarbonate roof and glass side for all year round use and I was previously advised to keep it at 20
    Donldson's Avatar
    NW Ohio
    2,896
    The CYA view tube that comes with the TF-100 can measure down to 20, the one that comes with the k-2006 can only measure down to 30. You want your level high enough to get a reading so if you are using the k-2006 then you will need to bring it to 30. Unfortunately TFTestkits cannot ship Taylor chemicals outside the US, but you might contact them about possibly getting a view tube and mixing bottle. Not sure shipping costs would make it worthwhile but it is one option if you would rather keep your CYA lower. Truthfully though, the difference between maintaining at 20 CYA and 30 CYA are minimal.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Stump's Avatar
    Jul 2013
    Oklahoma
    145
    If you can get a TF-Test kit CYA measuring cylinder which measures down to 20.
    TFTestkits.net
    24' Reprieve RD/AG/13K gal Vinyl TFP method
    Waterway Clearwater 175 sqft Cartridge
    Hayward Power-Flo Matrix 1HP Pump 2-Speed
    TF-100 Test Kit SpeedStir Borate Insta Test
    Spreading TFP to All
    Nov 2014
    United Kingdom
    220
    That seems ideal, why don't they ship that in the kit
    My problem is being in the UK it takes ages to receive it, that is if I can find someone to ship it
    Stump's Avatar
    Jul 2013
    Oklahoma
    145
    Dennis I don't know why Taylor sends tube min of 30ppm for CYA with their k-2006-c and the tube sent with TF 100 reading min 0f 30 is Taylor made and which I assume from TFT Testkits website the replacement is described as being Taylor.
