Results 1 to 12 of 12
Thread: Converting to Chlorine from Baqua
    Jun 2016
    Bath, MI
    5
    I am trying to convert from Baqua and having trouble! I purchased a product called Exchange to convert and followed directions on the bottle. I have a 24 ft round and 4 ft deep Doughboy pool. Our DE filter seems to gain pressure quickly. We have had to take it apart 3 times already and throughly clean it. It actually was just 36 hrs this time before the pressure went up! That was great as it had been maybe 12 the other times. Just backwashed now so will see how it goes. My water looks like Mountain Dew! My test sticks show no chlorine! I have added a gallon at a time about every other day for a week. Should I keep adding more chlorine? I also have added stabilizer in the amount my pool guys told me too. Getting frustrated with this process and kids are dying to swim. Any ideas?
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,237
    Re: Converting to Chlorine from Baqua
    Welcome to TFP! Good to have you here
    I have no experience in this. You have probably already found this, but here's an article in Pool School Pool School - Convert Your Baqua Pool to Chlorine
    Someone with experience will be along to help pretty soon
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    443
    Welcome...Follow the steps in the post that @needsajet linked.
    First things first though, get yourself a recommended test kit (linked in my signature). Your success and ease of conversion are more or less predicated on that.
    (Once your pH is adjusted to 7.2) You should only have to add liquid chlorine to your water and lots of it. You're getting frustrated because you are not adding enough Chlorine fast enough. However without a kit, you won't know how much each dose should be. Stop using test strips. They are less than accurate at best and don't add anymore stabilizer. The more you add, the higher level of FC you'll have to maintain. Essentially, you'll be doing a medium to large scale SLAM.
    One more thing. I don't have any experience with a DE filter and limited knowledge, but if you can circulate the water while bypassing the filter (at least initially), you won't have to clean and re-clean the filter as often.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    How much stabilizer have you added?
    Love TFP? Become a
    TFP Supporter!
    Jun 2016
    Bath, MI
    5
    I've added 4 lbs.. It's not all dissolved yet!
    Jun 2016
    Bath, MI
    5
    I also just added another gallon of chlorine. What does slamming with chlorine translate into for amounts?
    Jun 2016
    Bath, MI
    5
    Chris, Where can I get the test kit? I can't seem to finds your signature so can't see the test kit you posted. I would order one today if I knew what to get. Would it be on Amazon? Thanks so much for your help!
    needsajet's Avatar
    Jan 2016
    4,237
    TFTestkits.net
    You can order there. Add the XL option for sure, and speed stirrer if you can swing it.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Order a TF100 and at least include the XL option. That will give you what you need while you are clearing the pool, and probably enough reagents for a couple of years normal use.
    I also have the SpeedStir and Sample Sizer. They speed testing and accuracy.
    Support the site
    needsajet's Avatar
    Jan 2016
    4,237
    I have no financial interest in TF Test Kits, and the K2006C is another good option. TF is an active advocate of TFP. If you're thinking of becoming a TFP supporter, you can make a modest tax deductible donation to TFP and get a discount at TF Test Kits.
    Husky25's Avatar
    Jun 2015
    443
    Quote Originally Posted by Skimama69 View Post
    The link for a TF-100 is in my signature, but here's another link. It runs about $70, but once you complete the conversion, the TFP method will save you $$thousands in the seasons to come.
    I go through a case of 12.5% concentrated liquid chlorine in just over a week ($11.96/case) and unless I am vacuuming, I spend less than 5 min/day on pool maintenance. Compare that to Baquacil Sanitizer (close to $40 for 1/2 gallon, even if it's an off-brand), Oxidizer ($30/case), Algaecide ($20/qt.) and test strips ($10-$15) that don't work, and the $70 for the TF-100 pays for itself inside of a month.
    Chris
    Jun 2016
    Bath, MI
    5
    Thanks Chris. I ordered the test kit so it's on the way. I'm hoping it will help clear my pool that looks like Mountain Dew today. Really appreciate your help.
