Thread: White sediment
    May 2015
    Naples/Florida
    3
    White sediment
    Pool has been in for a year, SWG used, all pool care done, chemical balances normal. So lately there has been some white sediment on the bottom that is consistency of flakes or sand. Moving it around it seems to disappear, but I can see it again later. What is this?
    In ground 7000 gallons pool, no SPA. (11x21 rectangle, 3 ft to 5 ft deep). Plaster/Pebble. Pentair pump, Weather King electric heater, AquaCal Autopilot salt chlorine generator (Digital Nano).
    Constructed March 2015
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: White sediment
    Maybe calcium flakes from your SWCG. Give us a little info. Test results and any chemicals you routinely add to the pool.
    May 2015
    Naples/Florida
    3
    Re: White sediment
    I will clean the salt generator fins to see if that is the issue. Usually only added is acid for PH balance. Salt level is 3000-3200
