Thread: Another pool refilled with fresh water
    Feb 2016
    CYPRUS
    56
    I have been asked to look after my friends pool when they saw how mine looked using this great website. I totally drained it as as the CYA was 200 ppm. Anyway pool is refilled and here are my latest results. This pool is 20000 gallons, vinyl lined with a 1.5 kripsol pump. I am using a Pool Exact EZ photometer tester.
    FC 6.2
    CYA 52
    TA 82
    PH 7.5
    CC O.O1
    The water is lovely and clear but is using quite a lot of chlorine (strength is only 4%) Should CC be 0 or are the results OK?
    10300 Gallon vinyl pool, 0.75 Kripsol pump, glass filter, Pool Exact EZ photometer tester.
    9500 Gallon vinyl pool, 0.75 Kripsol pump, glass filter, Pool Exact EZ photometer tester.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Another pool refilled with fresh water
    I have no clue what that tester is, but for the sake of discussion I'll assume it's accurate. If the daily FC loss is 2-4 ppm that's considered normal.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,387
    I am with Mr. Bruce and want to add that with the strength only being 4% it WILL seem as if a lot is being used but there is not much chlorine in each jug.
    Kim
    Feb 2016
    CYPRUS
    56
    Screenshot from 2016-06-17 15:46:12.jpg
    Thanks for the replies. This the tester I use and is it very accurate, unfortunately I cannot get the test kits that are recommended on here in Cyprus. The liquid Chlorine is the strongest I can get here and comes in 20 litre containers (5 US Gallons ) but is relatively cheap at 7 euros (7.8 US dollars). The FC loss is in the range you mention, at the moment the temp is nearly 40c (104f)
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    You might want to add "Cyprus" to your location. For all I know it's somebody that can't spell Fresno
    For what I understand, accurate electronic testing is very expensive and requires frequent calibration. I understand the Cyprus thing, I'm not sure what you can do.
    Except maybe visit someone in the US and take a keepsake home!
    If it's that hot and sunny, yes, you're going to go through a lot of FC.
    Feb 2016
    CYPRUS
    56
    Quote Originally Posted by Mr Bruce View Post
    Thank you, I have changed it to Cyprus.
