Results 1 to 13 of 13
Thread: What do you think?
    Jun 2016
    Atlanta/GA
    33
    What do you think?
    I have been doing the trouble free method for about a week now but have owned my pool for 13-14 years.
    These are my most recent numbers.
    FC- 5
    CC- 0
    PH- 7.6-7.7
    CYA- 50-60
    TA- 100
    Do these all seem OK? And after a week my average chlorine loss is 3ppm a day.
    Temps have been in the 90s everyday and my pool gets full sun 90% of the day.20160616_141100.jpg
    24' Round above ground, 52in deep, Cooper Ranger series 200# sand filter, 1.5 hp pump Jacuzzi pump
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: What do you think?
    The FC is the minimum for your CYA but other than that I don't see any problems.
    Print this out and look at it often Pool School - Chlorine / CYA Chart
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2016
    Atlanta/GA
    33
    Already studied it, its closer to 50 so I was going with 4-8. But 5 minutes after I tested it I raised it to 8ppm. But is that an acceptable loss for one day? 3...I guess because the high temps and direct sun all day. Thanks for the feedback. Should I worry much about the PH being at the higher of the limit? Will it creep higher?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    If you're not sure about your daily loss being "normal", you can always perform the OCLT to reassure yourself. Keep an eye on the PH, but since you don't have a water feature or an SWG, it might not go up much.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    7.6-7.7 is fine. Once it hits 7.8 I'd bump it down to 7.5. The TA/pH relationship is usually pool specific and takes some time to get dialed in.
    Jun 2016
    Atlanta/GA
    33
    Will lowering my TA affect and possibly lower my PH over time?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    It's unlikely that a lower TA will lower your pH "automatically". As you bump pH down your TA will lower. You might find a happy spot, my pool seems to really like pH - 7.6-7.7 and TA of 60. It took me 3 years to figure that out.
    TA is worried about more than it should be. It's fine tuning, and should only be worried about if pH raises drastically or swings around like crazy.
    Jun 2016
    Atlanta/GA
    33
    Ok. I guess I will just leave it then and monitor it. I guess a few weeks after seeing how much loss there is a day yall don't check clorine but weekly? Since the oto kit only reads to 5ppm and I need to check a range of 4-8. Or do you guys use the FAS/DPD daily?
    Felt awesome to take my tf-100 kit top a buddies pool last night and check it for him. His cya was 100...once I told him the range his FC should be he said no way that can't be right, I don't think I am going to do it that high. I said ok...you will continue to fight algae. So we will see what happens. Maybe he will listen.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Weekly is too long to wait between testing. I test about every other day, some people stretch it to 3 but that is with some history and "learning" their pool's appetite. And I do the FAS-DPD every time, since 3 and 5 is a big difference with my CYA and I can't tell the difference in 3 and 5 yellow.
    IMO that OTO test is a "Is there SOME FC the pool?" sanity check.
    e: I added pool care to politics and religion as things to not talk about in public.
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by Mr Bruce View Post
    It really depends on the pool (and the pool owner i suppose ). My pool tends to be very stable and other than lowering PH once or maybe twice over the entire season i know that all i need to do to maintain my chemistry is half a gallon of 10% every day. I used to test every day but am down to once a week now and have no issues whatsoever.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Jun 2016
    Atlanta/GA
    33
    Should I raise or lower my cya?
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by Grated View Post
    I wouldn't. That far south you are probably just about at perfect at 50. Just keep your chlorine above minimum recommended levels and go swimming
    Haywood Sand Filter
    Vinyl Liner
    Jun 2016
    Atlanta/GA
    33
    Sounds good to me. Gonna keep it on the high end.
