Thread: New SWG and adding salt
    I'm in the process of installing my SWG. I'm about to go and buy the salt, Home depot I guess, and was wondering how to add it....Just dump it all in, brushing it around now and then. Or add it 1 bag at a time. How long does the salt take to dissolve.....
    Thanks
    17,200 in ground Vinyl pool......
    Salt Water
    Sand Filter
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: New SWG and adding salt
    I dump it in the deep end and brush it to the main drains. It doesn't take a long time to dissolve. Moving it around helps. Make sure you get the salt with no additives.
    I do a couple of bags at a time.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Mar 2008
    Central VA
    328
    Yep, I put it in the deep end and brush it...you probably want to use the pool calculator (link below) to figure a starting estimate for how much salt you need. Go a little low at first (maybe a bag or two below recommended), then give it at least 24 hours before you add more. Using salt test strips is good, but I've also noticed that my SWG needs a day or two to 'realize' that I've added enough salt, so the light may show "Low" for a day after I add the salt, then change to "Good."
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Be sure to test your current salt level before you calculate your dosage, often pools already have a salt level and if you don't account for that you could end up too high.
