Results 1 to 15 of 15
Thread: Will Metal Magic Remove Metal Staining?
    May 2015
    Moorpark, CA
    171
    I have light staining over the entire pool plaster which gives the blue pool plaster a yellowish tinge. I had some dark small 1/2" stains that I removed with ascorbic acid tablets. This actually cleared a yellowish tinge area around the dark stain, too, for about a foot. I read about Metal Magic on here, and am wondering if people here think I should try Metal Magic to remove the yellowish tinge. I was going to do an ascorbic acid treatment, but it would seem Metal Magic would be much easier.
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Will Metal Magic Remove Metal Staining?
    Sometimes it is possible for sequestrants like MM to left stains. It is worth a try and if it doesn't then you can do the AA treatment.
    Have you seen these articles in Pool School?
    Pool School - Metals in the Water and Metal Stains
    Ascorbic Treatment to rid Pool of metal stains
    Apr 2016
    Dallas, PA
    44
    Quote Originally Posted by Michael1 View Post
    I get the SAME light yellow staining as the original poster over my white fiberglass. It's very persistent but it is instantly removed with AA. Metal tests in my pool show up nothing and my CuLator bag stays white, meaning I'm wasting my money on these bags.
    Does anyone know what these light yellow stains over the whole pool are from? I originally thought it was copper, but also read that AA does not work well on copper, which leads me to believe it may be iron?
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    You could try Jacks stain ID kit to find out for sure if your stains are iron, copper, or organic.
    Stain ID Kit - 4 oz - #JMSTAINID - Stuff for the Pool - Our Stuff - Product Catalog - Jack's Magic Products, Inc.
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    May 2015
    Moorpark, CA
    171
    Quote Originally Posted by carlos31820 View Post
    Sent from my iPad using Tapatalk
    This is a very good idea. I really should know what the stains are. I know they aren't organic, but I don't know which metal.
    Michael
    May 2013
    Long Island NY
    419
    Those metal stains were a never ending problem for me for yrs. Even doing JM and AA and everything else on this site, I was always throwing money at the problem.The sorce of the metal is my city water supply. After a few yrs of capturing rain water and snow melt and avoiding the hose I'm finally about rid of the stains. For some this might not be an option due to where you live. Also keeping the ph low is a big help too!
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    May 2015
    Mount Cheaha Alabama
    250
    ^+1 on lowering your pH
    I tried a direct AA treatment a couple weeks ago, cleaned stains I'd just given up on over my 10yrs of pool ownership.
    Noticed my pH drifting towards 7.5-7.6 from rain aeration and bringing it back down to 7.2 with MA seemed to re-suspend the metal staining today&yesterday(without sequestrants)
    Just had a crazy t-storm roll through so we'll se what tomorrow brings
    30k in ground vinyl lined pool surrounded by decking in the woods.
    Hayward sand filter circa mid 80's
    If there is a way to do things less expensively and yield a superior product I am all ears
    Apr 2016
    Dallas, PA
    44
    Quote Originally Posted by basod View Post
    I am thoroughly confused though since United Chemical's website boasts the Hamilton Index where they claim keeping PH above 7.8 and TA low will be better for preventing stains, yet, this forum often says lower PH (around 7.2) is best to keep stains at bay. Can someone please weigh in on what is correct? Hamilton Index claims that the TA is more of a culprit for staining then the PH, but to keep the water balanced, to keep the TA low, you need to keep the PH higher.
    DFW, TX
    24,502
    Lots of different companies and places have lots of different ideas about how pool water chemistry should be managed. You get the task of deciding which one to follow for managing your pool and implementing it. If it doesn't work then try something new.
    Apr 2016
    Dallas, PA
    44
    Quote Originally Posted by pooldv View Post
    Totally agreed, but is it High PH or Low PH that is good for preventing staining? Or does it depend on other factors like your TA? I just see a lot of advice say, drop your PH to keep the stains away, but is it that straightforward?
    The first year I had my fiberglass pool I had bad copper staining over the whole surface, and I used those dreaded chlorine pucks.. My PH was always low, like 7.2, and I still had staining.
    Nov 2010
    Midland, Georgia
    353
    Low pH (acidic water) helps keep the stains away or lightens them.
    May 2013
    Long Island NY
    419
    Before you spend any money on anything else, just try lowering your PH to 7.2, wait a few days and see what happens. You may like the results. It won't make it look like you gave it a strong AA treatment, but it may end up being something you can live with.
    Apr 2016
    Dallas, PA
    44
    Quote Originally Posted by samt View Post
    I still don't understand why other indexes have the PH targeted for a 7.5 - 7.8 or even higher range then? What's the benefit of the higher PH if it's more prone to staining?
    May 2013
    Long Island NY
    419
    Quote Originally Posted by Draco1219 View Post
    I have no clue, Im the furthest from a chemist you will find. Im just reporting on what works for me. I have tried everything to get rid of the metal stains and from what I can tell ya if you don't completely replace your water and you have iron in your water, all treatments are a temporary fix. As soon as you quit treating the stains they will reappear. When I lower the ph the stains weren't as bad. I don't understand it either but it works for me. It's free too! Lower ph hasn't hurt my eyes or pool equiptment so that's that's what's important to me.
    The recommended higher levels of ph is what is more natural to the body I believe, but don't quote me on that. Someone else can chime in on that if they please.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Michael, the way to find out conveniently if Metal Magic will work is to do this sponge test:
    http://www.proteampoolcare.com/image...SpongeTest.pdf
    Here's why that's your best route: if you buy a startup dose of MM and do the test, and it doesn't work or will take too much, you can STILL do the AA treatment but you've already bought the sequestrant you'll need to complete the AA treatment. Make sense?
    PS re ph...low ph keeps metal in solution.
    I suspect United chem is saying high ph b/c the want to release the metal, then grab it with product in effort to carry it out or sequester better. I may go read to clarify, but that's the ONLY reason higher ph is indicated in metals.
    Eg MM does the same insofar as instruction say ph to be above 7.5 when adding sequestrant.
    Okay, ignore that. The Hamilton index is its own animal and is using ph to manipulate the csi with lower TA. Their method may be a little to variable-specific.
    TFP already recommends lower TA in general and is in essence controlling in a similar but broader fashion, I believe.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
