Results 1 to 8 of 8
Thread: Ants near skimmer - dropping sand into skimmer
    Feb 2015
    Grand Rapids MI
    54
    We've always had ants around our concrete pool deck but this year they have gotten right next to one of the skimmers. They are dumping a lot of dirt / sand into the skimmer as there is a small gap where they can come through. Any ideas on how to get rid of them without putting poison into my pool water? Anything natural that can go into pool water that will drive them away?
    18,000 gallon in ground vinyl pool. Sand filter.
    Aug 2014
    Northern IL
    4,615
    Re: Ants near skimmer - dropping sand into skimmer
    I use poison.... Can't help. The buggers survive the poison but do move their nests further away from the pool. We have a truce.
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Diatomaceous Earth? That's what we use to kill our beds but it's not effective on the ants once it gets wet. We also use boric acid traps. As far as I understand it both would be safe for the pool...
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    I had the same problem for the first time this year. I sprayed Home Defense inside the skimmer, along the deck and coping joint and around the edge of the pool deck adjacent to the skimmer lid. That was a few weeks ago and they are still gone even after lots of rain.
    Oct 2007
    Cedar Hill, TN
    252
    For a truly poison free solution, if you know where the nest is- pour boiling water on it.
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    Aug 2015
    Cypress
    1,679
    Quote Originally Posted by heikejohn View Post
    We've done that many times but they end up popping back up in other areas of the yard. It would be very effective if they just needed to be removed from near the skimmer though. Maybe doing that and setting some homemade boric acid traps would eliminate them permanently - for awhile.
    Feb 2015
    Grand Rapids MI
    54
    Interesting. So it's really ok to spray Home Defense (or other ant killer sprays) right into the pool basically? I just thought it wouldn't be safe to swim in after that. So I am wrong?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I've had good luck with Advion ant gel. It's a bait that they love. They take the bait back to the colony and kill more of them.
