Thread: FC and CC test
    May 2016
    Suwanee, GA
    11
    FC and CC test
    I am testing my FC and TC per the Chlorine Drop Test instructions on my TFTestKit I recently received. Seems rather straight forward but when I add the R-0871 solution one drop at a time the mixture will gradually turn from pink to clear as per directions . But the solution will only stay completely clear for say 30 seconds and gradually I t begins to it go back to a shade of pink--
    My question is --Is it accurate to take the reading when solution goes completely clear?? Why does it turn back to pink ? Am I to keep adding drops until it stays clear permanently ?
    Thanks !
    Jun 2012
    Butler, PA
    336
    Re: FC and CC test
    It does say in the extended directions if you leave it sit it will repinken (is that a word?, they didn't use repinken in extended directions, it just came off of these fingers naturally) ~ anyways it does say pink will come back in a minute or two. 30 seconds seems awfully quick, do you agitate by hand or do you have the speed stir?
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    38,285
    Re: FC and CC test
    That is normal. It will always turn back to pink if you wait long enough. If it is clear for a few seconds, you are done.
    When the sample is clear, you are done with the FC portion.
    Then add the 5 drops of R-0003 and count to clear again, then the CC is done.
    May 2016
    Suwanee, GA
    11
    Re: FC and CC test
    That's good to know --I must have misplaced those directions as I'm just looking at the laminated directions they sent--and I did not see anything referencing that --i can stop wasting the solution now-- 30 seconds was Just a guess I never really timed it--just knew it was not instantaneous ..
    Thnx
    38,285
    Re: FC and CC test
    The extended instructions are on the forum in Pool School.
