Thread: First OKSWIM Test
    Aug 2015
    Tuttle Ok
    30
    First OKSWIM Test
    First test using new TF-100 and Taylor salt test
    Salt = 4600ppm
    FC = 3.5
    CC=.5
    CYA=30
    CH=375
    TA=180
    PH=8.2
    I am guessing I need to add some cyanuric acid to bring up CYA and muriatic acid to lower PH. What do you guys think?
    14'X42'' Summer Escapes AGP
    2800 GPH Intex Pump with Hayward S166T Sand FIlter and Krystal Clear SWG
    TF-100 Test Kit w/K-1766 Salt Test and Speedstir
    Jul 2014
    Hope Mills, NC
    567
    Re: First OKSWIM Test
    Salt is kinda high also, but if the SWG is OK with it, leave it alone.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Aug 2015
    Tuttle Ok
    30
    Quote Originally Posted by Griswald View Post
    Ok, It is working well, so I will leave it for now. With the kids playing in the pool, some will be splashed out and It should lower a little over time I would think. Thanks for your help.
    May 2016
    Tulsa, ok
    49
    Hello from Tulsa. Yes, you can treat your CYA and Ph simultaneous. Dont pour acid on top of your cya.
    ~17k gallon, plaster/gunite pool, Pac Fab Challenger Pump 1.65HP, Sand filter. Rheem Heater. Waterfalls with 1 hp pump. Main Drain and 1 Skimmer.
    TF-100XL test kit
