Results 1 to 8 of 8
Thread: FAS/DPD Chlorine Test kit?
    Jun 2016
    Augusta, GA
    32
    Hi All,
    I am a convert to the TFP method. Pool is looking good. However, I need to SLAM the pool and therefore ordered the FAS/DPD test kit. It arrived today, I'm excited about getting this SLAM going, but the directions say to add a "heaping scoop" of the powder. The online directions say to use the included 'dipper'. My kit has: A chlorine only bottle, the R0870 container, the R-0871 bottle, and the R-003bottle. What is the 'dipper? Should it have come with my kit? And in the absence of this, can someone tell me what a 'heaping scoop" is? (e.g 1 tsp?????) what? Silly to have paid for a kit without a dipper? But am I missing something here?
    21,000 IG vinyl, Goldline AQ-LOGIC-P4, 2017 Pentair Sand Dollar Top Mount Sand Filter, Flotec AT251001-01, Hayward T-15 Turbo cell
    Augusta, GA
    Donldson's Avatar
    NW Ohio
    2,902
    Re: FAS/DPD Chlorine Test kit?
    This is the dipper: TFTestkits.net
    If it is missing and you got your test from TF Testkits, contact them and they will rectify the situation right away. If you ordered from another source you will need to take it up with them. In the meantime the amount of powder used for a 5 ml sample is about the size of a small pea or the tip of a sharpie, if that gives you a useful idea. Much, much less than a teaspoon.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    38,305
    Where did you buy the kit? If from tftestkits.net I think there should have been a scoop (little blue thing).
    It is not a big deal, a Popsicle stick or similar would work. The amount is like a small BB, much less than pea size. Just add enough that the sample turns a nice pink to start. You can not add too much, but too little could make the end point a little harder to see.
    Note in the picture that was just linked to the scoop is the small far end, not the flat wider handle.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I would describe the scoop as about the size of a BB.
    Donldson's Avatar
    NW Ohio
    2,902
    Quote Originally Posted by pooldv View Post
    That is the thing I was trying to think of but couldn't come up with. If those darn Starlings were outside my window again I would have thought of it really quick
    38,305
    Think ... the straight clip on Bic pen caps
    Or maybe Air Soft pellets (which are actually a little bigger than you need).
    Jun 2016
    Augusta, GA
    32
    Ok, great! Just what I needed to know. Yeah, got the kit through the TFtests site. I'll contact them...
    thanks all!!!!
    Augusta, GA
    Jun 2014
    Roseville, CA
    343
    Or cut a match head off and use two, possibly three measures for the 10 ml sample.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
