Results 1 to 8 of 8
Thread: Checking in with first TF-100 test results
    May 2016
    Overland Park, KS
    11
    Hi TFP Forum! As noted when I first joined, I did get a TF-100 kit and have run my first tests.
    FC 4 ............... (Pool Math Goal 3-10)
    CC .5
    PH 7.6 .............(Pool Math Goal 7.5 to 7.8)
    TA 90 ............. (Pool Math Goal 60 - 80)
    CYA 70 ........... (Pool Math Goal 70 - 80)
    CH 225 ........... (Pool Math Goal 0 - 300)
    About the only thing I can see that could be tweaked is the TA. I could lower the PH with Muriatic which will lower the TA and then let the PH rise via aeration - something I have no shortage of with my SWG and waterfall. I'll start with 2 quarts and see if that gets the TA down closer to 80-85. It took a while and a lot of adding to get the CYA up to 70!! I'm going to grab a 25 lb box/bag to rebuild my supply.
    Any comments or suggestions based on my numbers?
    24,600 Gal, IG freeform gunite w/vinyl liner, Triton II Sand Filter, Pentair 2.5 HP Whisperflow 2 speed,
    Pool completed May 2014, Spa, IntelliTouch Automation, Intellichlor IC40 SWG, Prowler 820 robot cleaner,
    Testing with TF-100 Kit.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Checking in with forst TF-100 test results
    TA is fine unless you have pH issues. CH is not important (within reason) in a vinyl pool. How does the water look?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    38,548
    Re: Checking in with first TF-100 test results
    I would not bother buying more CYA ... it should not really drop much except from splashout or rain overflow.
    No hurry on the TA, numbers look pretty good ... I would bump the FC up a bit ... I would want a bigger buffer than just 1ppm above the absolute minimum.
    May 2016
    Overland Park, KS
    11
    Quote Originally Posted by Mr Bruce View Post
    Water looks like crystal !!
    May 2016
    Overland Park, KS
    11
    We've been getting a lot of evap from high temps and the auto filler is topping off daily. Assuming that dilutes CYA somewhat over time?. I'll leave it be though as noted.
    I was actually going to also target 6 for the FC and raise it up more than 4. Honestly I was shocked that my numbers were this good since I've been using 7 way guess strips for the last 2 years. I got some good advice from my pool builder right off about using muriatic acid and had added CYA in the past to reduce the drag on the SWG.
    I was glad to see the numbers were pretty well in line. I wasn't sure if being at 90 for TA was bad with the range topping at 80 or not. Understand that these are target ranges though.
    Thanks for the feedback.
    38,548
    CYA is not lost to evaporation. Only H2O evaporates, leaving the CYA behind.
    May 2016
    Overland Park, KS
    11
    Ohhhhhhh, OK then. Thanks for that info. I need to read pool school and the Chem threads again, must have missed that!
    Jul 2014
    Hope Mills, NC
    569
    I'd leave it alone, looks good.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
