Thread: Newbie confirming Clorox date code interpretation
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    I just bought several 121 fl oz Clorox Concentrated Germicidal Bleach ("8.3%"). The date code is "H3 16144 IL-1." To me this doesn't quite match the format posted on TFP several years ago (found while searching). In the store, I saw the "16," and assumed that was year of manufacture with "144" being the Julian component. But at home I searched TFP and found posts stating the third character (i.e., "1") indicates 2011 as the date of manufacture.
    Did I buy really old bleach, or has Clorox changed their coding system?
    Chas & Cheryl (first-time, third-year pool owners)
    Radiant Metric Oval AGP 16'x32'x52"; Pentair: Clean&Clear 150 Cartridge, OptiFlo 1.5 Hp 2-spd, and 320C Feeder (all mounted below water level); Taylor K-2006 & SpeedStir; Maytronics Dolphin E10 (aka Einstein)
    installation pics (2015-2016)
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Newbie confirming Clorox date code interpretation
    hmmm, I thought exactly as you did, year 16 day 144
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Chlorox uses a slightly different system. H3 is the plant where it was made 16 is the year and 144 is the day of the year, as in day 144 of 365. IL is the state where the plant is located. I looked it up just this morning!
    Bleach Expiration Dates | Clorox
    Love TFP? Become a
    TFP Supporter!
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Zea3, when I follow the link you posted, I find this:
    which is why I'm confused.
    Do you find something different at that link?
    Jul 2009
    Houston, Texas
    9,380
    In the example the code is A8809507. If we break it down the way it is in the example A8 8095 07, A8 is the letter and first number for plant A8. 8 is for 2008 and 095 is the 95th day of the year.
    Here is a link to the latest info on their website, which basically says the same thing first letter and digit are the plant code, the next two digits are the year and the next 3 digits are the day of the year.
    Clorox® Regular-Bleach should be replaced every year and stored as directed for optimum performance. | Clorox
    Which thread were you looking at for the date codes? There is one from 2014 and one from 2012.
    Love TFP? Become a
    TFP Supporter!
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Thank you! That's what I was looking for
