Thread: Automation Recommendations??
    Jan 2014
    Southern California
    58
    Hi guys, I've been remodeling my pool for the past few months. Now it's time for my equipment to get upgraded. I've upgraded my equipment to a Hayward Progrid DE Filter, pentair variable speed pump and two pentair whisperflo pumps for my water features. Now it's time for my old school timer to get upgraded. I'm not really worried about automatic valves but would like to turn my pool on and off from my Phone and also have the option for controlling solar heating later on. What products would you recommend for me? And what exactly do I need to purchase? Any help would be greatly appreciated. Also what do you guys think of used units? I've seen quite a few used aqualink systems for sale on eBay.
    Remodel Completion 8/22/16. Pool-16x32', Raised Stacked Stone Spa with Waterfall - 9x9', Pool Depth 4-6', Pentair Intelliflo VS Pump, Intelliflo VF Pump, WhisperFlow 2HP Pump, Pentair 320 Clean and Clear filter, Easytouch 8, Screenlogic 2, (3) Pentair Globrites, Pentair Intellibrite 5G, 1.5HP Blower, 4 Sheer Descent Waterfalls, Rico Rock Waterfall.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,494
    Re: Automation Recommendations??
    From my point of view, there is only one rule.. If you want automation use only one manufacturer, so that things play well together.
    Since you already have a Pentair VS pump (I assume an Intelliflo) then it only makes sense to get an EasyTouch with ScreenLogic2 for remote operation from your PC or phone.
    An EasyTouch 4 can serially control your VS pump and your other two pumps via relays. This would leave you only one relay for pool light or ??? So, I would suggest the EasyTouch 8.
    I admit I am a big Pentair fan, but if you already had a Hayward VS pump, I would have recommended the Hayward Automation system.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    I agree with Jim, stick with one manufacturer if you want the parts to play well with each other.
    Support the site
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    I too am a proponent for the EasyTouch 8 and ScreenLogic 2. This setup should work nicely with your setup.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
