Thread: SWG Winter and Cold Water
    Jun 2016
    statesboro, ga
    48
    I live about 60 miles northeast of Savannah, GA. My Pentair IC20 does not generate chlorine below 59 degrees.
    I am asking for guidance and recommendations as to which chemicals to use to keep the chlorine level up and any other chemistry that may go up or down during the winter.
    Thank you.
    Mod note: This post was moved from this thread: SWG Winter and Cold Water
    17,100 gal, AG ,vinyl, sand Hayward DreamLine, pump Hayward Power-Flo LX 1.5 HP single speed, august 2015 install, water test kit Taylor K-2005, Pentair IC20 SWG, water from community well.
    Jun 2014
    Roseville, CA
    343
    Re: SWG Winter and Cold Water
    I shut mine off for the cold season, so salt isn't an issue.
    Heavy rain is going to dilute your pool, so you should attempt to keep it in spec, and use liquid chlorine to prevent algae.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Jun 2016
    statesboro, ga
    48
    Thanks for the reply. I thought your post was from 2014, boy am i not smart. When you say liquid chlorine are you speaking about something like Clorox from the supermarket?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,618
    I have some links for you. They are what I give people new to pools. It is a LOT of info. so take it a bit at a time and let it sink in before you move on.
    Print these out:
    Bookmark these:
    http://www.troublefreepool.com/calc.html
    Make sure to ask any and all questions you might have no matter how small! We have all been where you are at one point.
    This should help you with your original question as well!
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    I turn off my SWG when water drops below 70f and start using generic 8.25% bleach from the grocery store. I dose it up to about 12ppm usually and when it drops back to 8 I test PH and dose it back to 12.
