Thread: Thank you TFP
    Apr 2016
    Anderson, SC
    11
    Thank you TFP
    I don't post much....mostly lurk. Started reading this board last year this time and used the knowledge gained to recover my swamp starting in April this year. I'm proud to report the following numbers:
    FC: 4
    CC: 0
    TC: 4
    TA: 90
    PH: 7.5
    CH: 50...Low but I don't think it matters in my vinyl lined pool
    CYA: 40......I'll probably raise this up some as my pool gets full sunlight after 10 AM and it only 100 degrees in SC right now.
    Water temp is 92 so its dang near bath temp right now. We are supposed to get a break from the heat this weekend so I'm hoping to drop back into the 80's soon.
    I've probably read every article and post on the board a few times over in the past few months. I grew up with pools and have swam in probably a 100 different ones but mine is definitely the best "feeling" water I've ever experienced. And its crystal clear.
    Thanks for all the help TFP!
    IG vinyl liner, 26,000 gallon, Heyward sand filter with 1.5 HP pump
    38,262
    Re: Thank you TFP
    Fantastic to hear
    It really is easy when you get good information.
    If you are able, consider Becoming a TFP Supporter to help us keep the forum running. At the rate we are growing, a server / software upgrade is going to happen sooner than later.
    Jun 2014
    15,037
    Re: Thank you TFP
