Results 1 to 9 of 9
Thread: Pump motor humming, but not turning.
    I store the pump motor inside all winter (its a Hayward I believe). I hooked everything up yesterday and when I turned it on the pump motor hummed, but would not turn. Just wondering what I can check myself before I have to take the the thing to the shop. Thanks.
    25K Gal, IG gunite, Hayward 1HP pump, Hayward DE filter, Pentair Mastertemp 250, TF100 test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pump motor humming, but not turning.
    Welcome,
    We'll need more information on your equipment, brand/model, etc.
    You can put all your pool and equipment info in your signature -
    Go to User Control Panel, then Profile, then Edit Signature.
    One of the equipment gurus will be along shortly to chime in.
    Great, thanks! I am at work right now. I will add the information as soon as I get home.
    Apr 2009
    Sarasota Florida
    143
    Quote Originally Posted by sworth1
    see if you can turn the impeller by hand. if its frozen then the bearing have seized most likely.
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    Sometimes, if you can turn the shaft a turn or two by hand you can often get it unstuck, and the motor may then start normally.
    Other times, giving the pump a solid bump with a 2x4 (not hard enough to dent it) will unstick the starter switch and it will then start normally.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    The motor could have seized, and if so should respond to hand-turning (with power off) to break the 'stiction'.
    Since you unwire it to store and reconnect it to install, I would first look to make certain that the connections are good, that the capacitor hasn't gotten disconnected, and that it is wired for the correct voltage. 120 volts on a motor wired for 240 often results in a hum.
    Aug 2007
    near the swamp
    806
    try a new capacitor
    Western KY
    36
    Try replacing the starting capacitor or the centrifugal switch may not be functioning properly.
    20,000 gal. Vinyl
    1.5 hp pump 300 lb. sand filter.
    patrick3229's Avatar
    Feb 2012
    263
    Here is a step by step Guide with video on How to replace a pool pump capacitor it may be helpful to anyone else experiencing this same issue of the pump humming but not turning over which is a pretty common problem.
