Results 1 to 12 of 12
Thread: Test result discrepancy
    Sep 2015
    Aberdeen, NC
    12
    So I still consider myself a "new" pool owner and need some help. I have a tft-100 test kit and tested the pool today. I got a FC of 2, CC of 0, pH of 8, Hardness of 275, alkalinity 30.
    I took a sample of pool water to the local store and got a huge discrepancy with FC 0.86, CC 0.15, pH 8, Hardness 148, alkalinity 35.
    I got both samples about elbow deep. Now the home test I got from a less deep part of the pool but don't think this could account for the big difference in chlorine and Hardness.
    Any help would be great
    For ref, I have a Jandy Aquapure with AquaLink salt water pool ~40,000 gallons I think.
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Test result discrepancy
    Any comparison to a pool store test is invalid. Just throw them out, maybe a pH test exception. Trust your's, if you are concerned with your skill practice or watch youtube videos or videos @ TFTestkits.com
    In reality, the results are fairly similar. Neither result has a CYA reading tho??
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Aug 2014
    Northern IL
    4,615
    Why bother comparing your results with those guys? Us guys give better advice! Trust your test.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,664
    And THAT is why we have our own test kits!
    Kim
    Sep 2015
    Aberdeen, NC
    12
    Could j be doing the tests incorrectly? I follow the instructions in the TFT-100 kit. And it is pretty dang simple so don't know how I could be messing it up.
    Pool Tool's Avatar
    May 2014
    757
    You are not messing them up, you are fine. Watch the videos here to refine your skills. https://www.youtube.com/user/tf100te...e=results_main
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Unless they are using the exact same test method you are using I would trust your test results. If the pool store was using a computerized tester I would not trust it at all.
    Love TFP? Become a
    TFP Supporter!
    Sep 2015
    Aberdeen, NC
    12
    Quote Originally Posted by zea3 View Post
    It was a computerized tester at the pool store. She said trust her readings of course.
    Donldson's Avatar
    NW Ohio
    2,920
    This is why we insist on people getting their own test kit. It isn't to sell kits or because we laugh at making people spend $70, it is because we just cannot trust pool store testing. As you can see, some were close, some a little off, and CH not even close.
    You followed the directions in your kit, trust those numbers. No need to ever 'verify' your numbers at a pool store, you got this!
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Aug 2014
    Northern IL
    4,615
    There must be a part of you that still thinks the pool store is where the experts are. Wrong! We are HERE!
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    492
    if you are still not convinced have a friend use your kit
    you should get the same results "within test paramaters"
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    Quote Originally Posted by MarianParoo View Post
    Realize that the nineteen year old who works there from may til august knows nothing about water...just owning a tf 100 makes you the smartest pool guy in the store each time you walk in!
