Thread: Pac-Fab Triton sand filter
    Jun 2016
    East Central MS
    115
    Any idea how much sand should be in my filter? Since I had to replace a lateral recently, I decided just to change it out and have added somewhere around 350 pounds of new sand. 500 pounds was recommended to me, but I don't have the care guide as I believe the filter is original to the pool (1977). Thanks.
    34K gal, 20'x40' IGP (backfilled and reinforced concrete block walls with concrete floor built mid-1970's; renovated 2017), PebbleSheen Arctic White plaster finish, Lotus Prisma Marine 1x2 glass waterline tiles, Indiana limestone coping, 1.5hp Hayward pump, Pentair Triton II TR100 sand filter, Pentair Intellibrite 5g color LED 120v Pool Light, Dolphin Supreme M400 robot, Stenner 45M1 pump, Pentair 320 chlorinator (to raise CYA only)
    Dec 2014
    Houston, Texas
    134
    Re: Pac-Fab Triton sand filter
    What is the size of the filter (40,50,60,100,140)? W/o that we'd be guessing. If you don't know the size you could just fill to the point where the sand covers the top pipe.
    Jun 2016
    East Central MS
    115
    It's a 100
    Feb 2015
    Chandler AZ
    922
    http://www.pentairpool.com/products/...ilters-183.htm
    Click on "Specs" on the right.
    Looks to be 600# for the tr 100 - or - 150# gravel on bottom and 450# sand.
    You can get the manual from the above link too.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
