Thread: Cost to add a ladder to an inground pool
    spoonman's Avatar
    Jun 2016
    Peoria, AZ
    242
    Could anyone provide an idea of the cost or difficulty to add a ladder to an in-ground pool?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Cost to add a ladder to an inground pool
    If you want a ladder that just slips into deck anchors, it's not overly expensive.
    $200 to $400 dollars for a quality SR Smith ladder. They're worth it knowing they won't disintegrate after a couple seasons. Mine is probably 20 years old.
    You'll need two anchors in the pool deck, likely about $40-60 a piece.
    Isolated Spa - 345 Gallons
    Quote Originally Posted by spoonman View Post
    Metal ladder will require bonding/grounding; polymer/resin (Saftron) will not.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    spoonman's Avatar
    Jun 2016
    Peoria, AZ
    242
    Thanks for the info.
    How would a metal ladder be grounded if installed after the pool is built? Would a wire have to be run through the decking somehow?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I have a metal ladder that was never bonded (I bought the house late last year).
    What I did was chip away a small trench of the concrete deck then ran #8 bare copper wire from the ladder
    to the pool equipment. Then I covered the trench with a small amount of concrete.
    Then secured the wire to the ladder anchor bolt with a bronze washer (the anchor and bolt is bronze too)
    I feel much safer now with it bonded.
    Dolphin E10 Cleaning Robot.
    Apr 2013
    Sacramento, CA
    2,769
    You can saw cut in a line and run the wire through that. Cover the cut with grout to match. Or get a composite ladder that doesn't require bonding.
