Results 1 to 8 of 8
Thread: Neighborhood Pool Problems: Runaround reasons
    Cypress, Tx.
    154
    Our neighborhood pool has apparently tuned green and the pool company is giving a lame excuse, I think. Anyone care to give their opinion. This makes me glad I have my own pool
    "Further investigations also revealed the phosphate levels and TDS (total dissolved solids) in the pool water are too high. When this occurs, the cleaning chemicals are rendered ineffective. The pool will be closed for at least the rest of this week for a total change-out of the pool water.
    Thank you for your patience as these issues are addressed. Stay tuned for further updates."
    Intex 18ft dia. Ultraframe, 6500 gal. above ground Intex pool with Hayward C550 cartridge type filter and Intex Krystal Clear Ozone and saltwater system model ZS8110, Taylor K-2006 test Kit, Pool filter supplemented with Duda Diesel 1 micron filter bag
    Located in Cypress, Tx.
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Sounds like whoever is in charge of those chemicals needs TFP. I'll let experienced people answer the questions though, lol.
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Re: Neighborhood Pool Problems: Runaround reasons
    Neighborhood pool "pool stored." should be the caption
    Dolphin E10 Cleaning Robot.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Clear green, probably copper. Someone must have bought copper based algaecide.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    I bet if you tested the water the CYA would be sky high and THAT is what is keeping the FC from "working".
    Kim
    Donldson's Avatar
    NW Ohio
    2,893
    Unfortunately being considered a public pool if the CYA is sky high then adjusting the FC to the appropriate level is not possible, so even if their reasoning is bunk a drain and fill is the solution to the problem. Fun tidbit, phosphates prevent pipe corrosion so most municipal supplies have "high" phosphate levels coming out of the tap. The refill water will likely be just as high in phosphates yet miraculously not be green. Must be magic.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    My advice, don't use public pools. Also, hire a new pool company.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Cypress, Tx.
    154
    We haven't been to the neighborhood pool in years. I'm just watching teh drama on the neighborhood message board.
