Thread: Chlorine output from pentair ic40
    Feb 2011
    Cincinnati, Ohio
    106
    Can someone tell me if running my pump at a higher rpm say 2000 will produce more chlorine than running it at say 1200 rpm for the same amount of time? I am guessing it will but not positive. My cell is on and the flow rate is sufficient at both speeds to keep the cell producing. Jus wasn't sure if the more water pushed through it at a higher rpm meant more chlorine or not. Thanks.
    18 x 36 IG Vinyl Liner 28K Gallons
    Pentair Intelliflo VS+SVRS, Pentair CC + 420 Cartridge Filter, Easytouch CP with IC40 SWG
    2" Suction and Return Lines - 2 skimmers, 6 returns
    Dolphin Diagnostic Advantage Robot
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Chlorine output from pentair ic40
    Cell output is determined by the output setting on the SWG itself. It doesn't matter what RPM your pump is running at, so long as there is enough flow to keep the SWG from shutting off.
    Isolated Spa - 345 Gallons
    May 2015
    Land O Lakes, FL
    527
    Click on my profile and look for a post about this same unit just a few days ago. I got a response from their support department on exactly how it works
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Feb 2011
    Cincinnati, Ohio
    106
    Thanks.
