Thread: Hayward Aqua Trol panel not reading correct salt level
    Jun 2016
    Gatineau, Québec, Canada
    4
    Hello everyone,
    I'm having a problem with my Hayward Aqua Trol panel since opening my pool last month.
    The panel reads 300 ppm of salt which is not high enough to start generating salt and the generating salt light turns red. The reading went as low as 0 ppm and as high as 600 ppm but won't go higher. I know I have the correct amount of salt (tested in store).
    I had the store test the cell on a new panel and the cell worked fine identifying the right amount of salt. The store tested a new cell on my defective panel and the panel reads 300 ppm.
    The store unfortunately told me they hadn't received the equipment to test the panel so I took everything back and that's where I am. (I not impressed by the service received by that store...). Any ideas?
    Joël.
    13,593 Gallon, Above Ground, Cartridge Filter, Haward salt generator (Not currently working), sunny all day, Taylor K-2006
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Hayward Aqua Trol panel not reading correct salt level
    Sounds like you need a new panel.
    Isolated Spa - 345 Gallons
