Thread: Chemicals out of whack!
    Jun 2016
    Saltsburg
    1
    HELP! FC-O/0 Ph.8.4 TA40 Hardness100 CYA 30-40 . I have shocked the pool a few times (Which cleared the algae) and added baking soda. My pool guy told me, oh dont worry about the CYA . Is that true? My ph went up and TA dropped and no matter how much chlorine I add it still reads 0. I am on a tight budget this year and this is getting expensive. I am about to order chems online and planning to go back to Bromine just because it seemed more manageable when I used it 3years ago and about 8 years before that. We have had lots a rain as well which could be adding to this problem? My test kit is just the strips from HTH.
    Pool size 28' x 52' round above ground, Cartridge Filtration System Hayward xstream,Pump Pro-Flo Matrix. Chemicals~ Chlorinating Liquid.
    FattyLumpkin's Avatar
    May 2016
    Massachusetts
    188
    Re: Chemicals out of whack!
    Someone with more experience than I will need to provide specific guidance, but I've learned quickly the first response: get yourself a good test kit (TF-100 recommended), throw the test strips away, and don't speak to the pool store.
    / 24k Gal, 18x36 Freeform IG Vinyl Saltwater / Sta-Rite MPRA6E-205L 1HP Pump / Sta-Rite System:3 Cartridge Filter / IC-40 SWCG / Dolphin Nautilus Cleaner / TF-100 Test Kit w/ SpeedStir / Taylor K-1766 Salt Test /
    Useful Links: Recommended Levels / SLAM / FC/CYA Chart / Test Kits Compared / Edit Your Signature
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Hi Pam! I am SO glad you found us here at TFP! We can and will get your pool looking like a jewel but we need you to help us do it. The help is getting a good test kit like FL said. Look in my siggy for the one I think gives you the best value for your money.
    While you are waiting for your test kit to get there please read this:
    This will tell you the whys and hows of TFP care. It is a lot of info. so take it in small bites. Once you get your test kit you will find it even easier to understand.
    Kim
