Thread: robotic pool cleaner mod?
    Jul 2013
    western new york
    62
    Is it possible to purchase a waterproof cable swivel seperately and slice it into you robotic pool cleaners existing floating cable? If so does anyone know if/where one can purchase this type of swivel? I am happy with my current robotic cleaner but I hate untangling the cord so often.
    15k gal inground Viking fiberglass pool; Hayward Variable 1.5hp pump (Maxflo VS); Hayward swimclear 325 sg ft cartridge filter; Raypak 206A 199k btu nat gas heater; Aquabot Bravo robotic pool cleaner
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: robotic pool cleaner mod?
    My Tigershark is a similarly designed robot. I don't have many issues with tangling. Are you changing the handle position before each time you run it?
    I don't believe there is a reliable way to add a swivel to a robot that does not have one.
    Isolated Spa - 345 Gallons
    Jul 2013
    western new york
    62
    Quote Originally Posted by JVTrain View Post
    no..I don't change the handle position often...maybe about once a month.. I know i should change it more often
    Quote Originally Posted by echo View Post
    2 Wire Cable Ez Swivel For Aquabot Pool Cleaner Power Cable
    They have different kinds for 2-wire and 5-wire
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Jul 2013
    western new york
    62
    Quote Originally Posted by Geebot View Post
    the swivel in your link seems like the type of swivel that one would use to help with an already tangled cable. I am looking for something that would help prevent tangling during the robotic cleaners use. (probably something that you would have to cut and splice wires and install closer to the robot itself rather than closer to the power pac.
    Apr 2013
    Sacramento, CA
    2,769
    They don't sell them because the manufacturers would go nuts. It's not a good idea to splice the cord.
