Thread: Waterproof paint using PVC fixtures help!!
    Question Waterproof paint using PVC fixtures help!!
    Hi everyone.
    The dream of having a pool is still on hold.
    no much progress since: WaterProof options needed
    Just finished the walls with mortar.
    Pool was build with the intention of aplying PVC to waterproof tank.
    Since pvc still to expensive i was thinking of doing some epoxi paint, to at least use it for a year or two.
    Now my question is:
    How to i use paint when fixtures in pool walls are for liner/PVC?
    Do i need to cut the ciment around the fixtures and apply some specific "silicon" around them before i paint the walls?
    please need some technical help.
    kind regards
    Goahead
    27' 17,000 gal, AG,cartridge filter, 2.5 HP Waterway 2 speed
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Waterproof paint using PVC fixtures help!!
    Welcome back, been a while...
    Just wondering, is there a reason you do not want plaster?
    from what you have there it is going to be an awesome pool when finished
    Hi Casey,
    Plaster is not something very common here in Portugal. Maybe a lack of experts in plaster technique?
    Armed PVC liners, soldered in place, is what builders use more often. More reliable and durable and can be adapted to any shape. but still expensive.
    I need a cheap solution for 2 or 3 years of use, that can hold some wall cracks.
    The thing is that i dont know if i can use current plastic fixtures for Liner, for other waterproof solutions.
    Some technical help needed. What should i do?
    Regards
    G.
    Jul 2013
    Fletcher, OK
    3,353
    I wish I knew..
    here they use these type connections for returns and skimmers
    Amazon.com : Pentair 506521 ABS 1-1/2-Inch Threaded Port Bermuda Wide-Mouth Vinyl Fiberglass Pool and Spa Skimmer, White : Swimming Pool Skimmers : Patio, Lawn Garden
    Amazon.com: Hayward SP1408 In-Ground Swimming Pool Return Inlet Fitting: Patio, Lawn Garden
    could you adapt these into your pipe and then connect the liner to them?
    just throwing out some ideas
    The propose of opening this thread, is to know if i can use epoxy paint with liner fixtures.
    The fixtures in pictures above, are for Liner and PVC armée.
    I want to use epoxy paint...
    Helpppppppppp
